1998 truck 5.9 drained battery now no spark
Old Mar 6, 2007 | 08:14 PM
rmkpower1's Avatar
rmkpower1
Default 1998 truck 5.9 drained battery now no spark
left the light on drained the battery down, recharged it now it won't start.. no spark? does crank over fast...
help!!
Old Mar 6, 2007 | 09:04 PM
bamory's Avatar
bamory
Default RE: 1998 truck 5.9 drained battery now no spark
Depending on how old the battery is you may need to replace it, have your alt checked out also.
Old Mar 6, 2007 | 10:59 PM
Rammer's Avatar
Rammer
I've heard that these trucks have a very fussy voltage sensor. When my battery drained for the second time, it would start, but not run well (almost like it was choking out). It would not idle, even after driving around for a while. I replaced the battery and everything worked fine. Try that.
Old Mar 7, 2007 | 12:57 PM
rmkpower1's Avatar
rmkpower1
the charging system & battery are fine the head lights were left on all night long... the battery is charged and it cranks fine no spark or noise from fuel pump.. also fuse for O2 & gauges do not have 12v to them?
Old Mar 7, 2007 | 12:59 PM
rmkpower1's Avatar
rmkpower1
Old Mar 7, 2007 | 03:31 PM
tdmopar59's Avatar
tdmopar59
did your check your fuses? Check your plugs for spark... Take your battery to autozone and have them test it too....
