spark nock
Old Mar 7, 2007 | 10:03 PM
ja7369's Avatar
ja7369
Default spark nock
I am getting alot of spark nock from the moto when i am in OD and the RPM are down. I thought it was the plenium but it was ok (i replaced anyway) Then i thought EGR valve but it doesnt have one ...I am open to any and all suggestions ...When i am in OD and give it gas it rattles bad and doesnt pick up unless it drops down to drive
Old Mar 7, 2007 | 10:47 PM
TMS Bill's Avatar
TMS Bill
Default RE: spark nock
Wait until it gets dark, open the hood (engine running) and look for a light show. You probably have crossfire between cylinders ... fatter plug wires can help solve that. If it all looks good, try dropping down a heat range or two on some new plugs.
Old Mar 8, 2007 | 12:42 AM
ja7369's Avatar
ja7369
had a guy tell me to put 2 cans of sea foam in tank and to take a vacum line off and pour sea foam into the line with rpms up ...he thinks it may be carbon build up
Old Mar 8, 2007 | 12:56 AM
TMS Bill's Avatar
TMS Bill
Some people say Seafoam works to clean out your CC's ... never used it myself. Read up on it some time ago, though. Never heard if it actually fixed any problems.
Not sure if you need to put any in your tank if you do the vacuum line thing (brake booster line is a favorite). Let the line suck it up and at the very end kill the motor. Let it soak for a while and when you start it back up you'll smoke out the neighborhood. If you try it ... lemme know if it fixes your pinging problem.
Old Mar 8, 2007 | 01:05 AM
TPSDODGE's Avatar
TPSDODGE
just go to the dealer and buy a can of conbustion chamber cleaner start the truck with the air hat off and spray the stuf in your TB then kill the truck and let it sit for 2.5 to three hours then go drive Have fun
Old Mar 8, 2007 | 10:30 AM
dhvaughan's Avatar
dhvaughan
are ya'll saying that the spark knock (pre-ignition) is caused by the extra heat from the carbon build up ?
2nd question.. is seafoam and mopar cc cleaner the same thing, or do the same thing ?
3rd.. TPS... how much does the mopar cost the walk up customer at the dealer ?
Old Mar 8, 2007 | 11:18 AM
Slade901's Avatar
Slade901
I usually put some on the gas tank and the rest on the brake line booster for good soaking on the intake manifold. If you live in the city, I would recommend doing it night as neighbors might complain of a huge smoke coming from your vehicle.
Old Mar 9, 2007 | 10:24 AM
ja7369's Avatar
ja7369
well I pourd 2 cans in with about 1/4 tank of gas and some down booster line (smoke like it was on fire ) let it idle for a half hour and then let it soak all night . So leaving for work will let yall know this afternoon
Old Mar 9, 2007 | 11:06 AM
Slade901's Avatar
Slade901
ORIGINAL: ja7369
You are suppose to turn off the engine after you have used up the can. Let it sit for a couple of hours to soak it good and then start the vehicle.
Old Mar 9, 2007 | 09:27 PM
TMS Bill's Avatar
TMS Bill
ORIGINAL: dhvaughan
The pre-ignition can (in some cases) be caused by the increased compression resulting from reduced volume of the CC due to carbon buildup.
2nd question ... no Seafoam and Mopar CC Cleaner are not the same product although they are used for the same purpose.
