OIL CONSUMPTION
Old Mar 10, 2007 | 09:40 PM
TMS Bill's Avatar
TMS Bill
Default RE: OIL CONSUMPTION
http://www.hughesengines.com/partDet...p?partID=11698
Only use the CC Cleaner if you've still got bad pinging after changing out the gasket.
Old Mar 10, 2007 | 09:53 PM
jram99's Avatar
jram99
I had the same problem, loosing to much oil to be just a leak. Reading this forum had me convinced it was the plenum gasket. In January I tore the engine down to replace the timing chain and front seal that was also leaking. There was about 3" of gasket blown out from the plenum plate. I never noticed any oil burning either but it had to be. I also didn't realize how long it'd been since I tuned the truck up, could barely get the plugs out. When I did, all of them had wet oil and carbon build up on them. I took a few shots of the intake before and after cleaning it up. I also snugged down the valvecover bolts. Some of them were pretty loose. Jeff.
Old Mar 10, 2007 | 09:59 PM
jram99's Avatar
jram99
Pictures didn't upload last post. Here they are. You can see how much oil was in the plenum. Jeff.
[IMG]local://upfiles/43161/98E973C29AD544899EAFD2F1E72744F1.jpg[/IMG]
[IMG]local://upfiles/43161/0E853E1D27DF4608BB1FDAD031ED43D3.jpg[/IMG]
