OIL CONSUMPTION
Old Mar 9, 2007 | 02:51 AM
3406pak's Avatar
3406pak
Default OIL CONSUMPTION
I have a 1997 Ram with the 5.9 and I am losing oil somewhere. Nothing is leaking on the ground and no blue smoke but yet still losing oil. Can anyone help?
Old Mar 9, 2007 | 03:12 AM
dhvaughan's Avatar
dhvaughan
Default RE: OIL CONSUMPTION
maybe plenum gasket. very common. do a search for lots and lots and lots of posts. the intake vacuum sucks the oil into the intake and burns it.
Old Mar 9, 2007 | 11:46 AM
Dodge4x4810's Avatar
Dodge4x4810
Most likely the plenum gasket.
Old Mar 9, 2007 | 01:01 PM
Slade901's Avatar
Slade901
It could be the plenum gasket like they said. I have been searching for the same problem with my oil consumption and I'm leaning towards the failing plenum gasket which likely the same problem you have. Are you having a engine miss around 40-50mph speed? Set your cruise control around 44mph or 45mph and see if you feel a miss.
Check this out http://dodgeram.info/tsb/2000/09-05-00.htm
and this
https://dodgeforum.com/m_249261/tm.htm
Old Mar 9, 2007 | 02:01 PM
2001mustang_gt's Avatar
2001mustang_gt
question...my friend has the same problem and we changed out his intake to the M1 no oil in nothing yet he is almost 2 qts down at oil change time...any thoughts?
Old Mar 9, 2007 | 10:06 PM
TMS Bill's Avatar
TMS Bill
How long does he go between changes? All engines burn SOME oil ... some more than others.
Old Mar 9, 2007 | 10:21 PM
dhvaughan's Avatar
dhvaughan
if its not leaking it, then its got to be burning it. either by sucking it into the intake, leaking/sucking it down the valve seals, or slipping past the rings. i used to just say oil is cheap, engine repairs/rebuilds are expensive. its not cheap anymore, but oil is still cheaper than major repairs. in my old chevy truck after about 200k miles i found that it used less oil with 40w or 50w rather than 10w30 or 10w40.
btw, where did he get his M1 intake ? do you know how much ?
Old Mar 10, 2007 | 01:22 AM
2001mustang_gt
he goes about 2500-3000 miles between oil changes...and we both ordered our intakes from mopar
Old Mar 10, 2007 | 01:48 AM
TMS Bill's Avatar
TMS Bill
Time for straight 30 weight.
Old Mar 10, 2007 | 11:10 AM
3406pak's Avatar
3406pak
Thanks to all that replyed to my post!
I did notice something this morning when I was letting the truck warm up there seems to be a faintsmell of burning oil thru the exhaust but no blue smoke. I do know one thing when I first got the truck I did an oil change and drove it for about 820 milesafter that. Last weekend was out getting some gas I had stopped at a light and the oil light came on, checked oil level and it wasalmost 3quarts low (GM's WOULD HAVE BEEN DONE ha ha!) I will investigate the plenum gasket and probably repair it.
One other question which brand of gasket is recomended and should I use the (Chrysler C.C. Cleaner)?
Thanks Too All!
Ken
