burn out/brake stand quuestion....
Old Mar 9, 2007 | 03:22 AM
spaz_22's Avatar
spaz_22
Default burn out/brake stand quuestion....
So i wanted to do a brake stand in my 2000 1500 4x4 with the 5.2 auto..completely stock..also has the lsd rear axle...so i tried to do a brake stand in my truck like i used to do with my other truck (93 f-150) hold the brake down as much as possible, and the slam the gas and let her rip....but i tried that in my dodge but all it did was rev to about 2100 rpms and squat...i put it into manual first and tried it again, and it revs again and starts to jerk a little...almost like it's trying to break loose....is there something i'm doing wrong? or is just impossible to do it on a dodge?
thanks in advanced
Old Mar 9, 2007 | 03:38 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Default RE: burn out/brake stand quuestion....
i couldnt do it until i got new tires, but let off on the brake a bit because you are locking up the rear brakes or you can get a line lock system
Old Mar 9, 2007 | 03:56 AM
RamMan_8520's Avatar
RamMan_8520
No it not impossible i just did one about 15 minutes ago cause im a little pissed off
Old Mar 9, 2007 | 11:30 AM
JarheadX's Avatar
JarheadX
i don't slam my brake down then slam on the gas, i see how high the rpms go until the tires break lose
Old Mar 9, 2007 | 11:44 AM
Dodge4x4810's Avatar
Dodge4x4810
Try holding the brake just enough for the truck not to move, not fully depress them. If that doesn't work, i would trying mashing the gas then applying the brake. Although if you want your tranny to last long i would not do this too much.
Old Mar 9, 2007 | 12:59 PM
shott8283's Avatar
shott8283
if you want some inspiration,, here ya go
http://videos.streetfire.net/video/9...27002aed93.htm
Old Mar 9, 2007 | 01:59 PM
2001mustang_gt's Avatar
2001mustang_gt
here is more inspiration
http://s65.photobucket.com/albums/h223/james_bobholz/?action=view&current=P1010055.flv
Old Mar 9, 2007 | 03:17 PM
Tani1500's Avatar
Tani1500
make sure u have over drive off. that will help. and like said you gotta keep it where it feels like the trucks about to go fowards and dont let it. or if this is like a one time show thing u can crank your rear brakes out. ( i will not be held responsible for that in any way)
Old Mar 9, 2007 | 03:22 PM
mopar98's Avatar
mopar98
U can also try a line lock.
I have one on my Firebird it's cool as heck on the road
and works great at the strip for warming up the tires.
Old Mar 9, 2007 | 03:26 PM
tdmopar59's Avatar
tdmopar59
yea you dont want your brake to the floor get on it just light enough that its not movin
then work the gas to get the rpms up (you might have to get on the break a little more if it starts rolling)
Then it should rip them
