Ignition Key Light on 2001 2500
Old Mar 11, 2007 | 04:53 AM
Flatfoot's Avatar
Flatfoot
Default Ignition Key Light on 2001 2500
Hello everyone.
The clear ring around the ignition key in my truck hasn't worked since I bought it. So tonight I took the column cover apart. I found a small bulb and figured it had just burned out. I took the bulb out and tested it and it worked. So then I grabbed my volt meter and tested the leads going to the bulb. I got about 5 volts. I guess not enough to light it. Has anyone else had this problem or know of a fix? Maybe a faulty relay or something?
I just found this forum tonight and love it. Great place!!
Thanks, Flatfoot
