suspension question
Old Mar 11, 2007 | 11:57 PM
dobbie146's Avatar
dobbie146
Default suspension question
I feel a clunk comming from under the drivers side floor at highway speeds. Front end feels tight and it doesn't clunk over bumps or any other time.
The truck also steers to the left slightly but doesn't pull.
I've been reading about the trac bars and still have a few questions.
What it the bar that goes from the tie rods and has a shock in the middle?
When I twist the bar(not pull) it has lots of movement at the joints, rocking back and forth. Is that normal??
Also is a loose trac bar bad for other suspension parts?
1999 1500 sport 4x4
Thanks for the input.
[align=left] [/align]
Old Mar 12, 2007 | 01:03 PM
dobbie146's Avatar
dobbie146
Default RE: suspension question
anyone??
Old Mar 12, 2007 | 10:10 PM
TMS Bill's Avatar
TMS Bill
The bar with the tie rod end and steering damper (shock) on it is the tie rod ... yes, it can move rotationally.
The truck steering itself to the left is the same as pulling to the left.
Yes, a bad track bar can play a part in wearing out other front end components.
Old Mar 13, 2007 | 02:00 AM
dobbie146's Avatar
dobbie146
how do you check the track bar?? some people say there will be play in it, some say you won't be able to move it??
Old Mar 13, 2007 | 02:20 AM
Bigfoot68's Avatar
Bigfoot68
Check the front axle u-joint. Mine made a clunking sound too. Very easy to change.
Old Mar 13, 2007 | 07:31 PM
TMS Bill's Avatar
TMS Bill
ORIGINAL: dobbie146
The track bar is what keeps the front axle centered and prevents lateral movement. It should only move a couple of millimeters (at it's ball joint) when the front wheels are turned left/right (lock to lock). That's not much. Any more than that and a replacement is in order. Don't replace it with a stock unit. [:'(]
