HELP????
Old Mar 13, 2007 | 07:07 PM
RamMan_8520's Avatar
RamMan_8520
Default HELP????
This is hard to explain but i need to find out what is is so i can fix it. When i have the heat or a/c on.... For example when it is on all feet or all vents it will automatically switch to defrost and then when i punch the gas and then immediately let off it will come back to the feet or vents i think it is a vacuum hose but which one i'm not sure which can anyone help
Old Mar 13, 2007 | 11:12 PM
hcast8's Avatar
hcast8
Default RE: HELP????
Dam thats weird I have never heard of that before hopefully someone can help you
Old Mar 13, 2007 | 11:58 PM
TMS Bill's Avatar
TMS Bill
Letting off the gas generates a high vacuum in the system. You've got a small leak ... look for cracked or brittle hoses or a loose vacuum line. The chances of it being a connection actually off is is pretty small.
Old Mar 14, 2007 | 01:48 AM
DieselDemon's Avatar
DieselDemon
Replace your check valves.
Old Mar 14, 2007 | 05:20 PM
Sirhilton17's Avatar
Sirhilton17
With my truck, if you hit the gas really hard, it will switch over to defrost but when you let off it goes right back... My old car did the same thing.
Old Mar 14, 2007 | 11:36 PM
mtrider's Avatar
mtrider
Diesel Demon is correct...there is a check valve in the system to stop that...change that.
I also added one to isolate the heater from the rest of the system on that line.
Old Mar 15, 2007 | 02:27 AM
RamMan_8520
Where is the check valve located??
Old Mar 15, 2007 | 02:57 AM
RamMan_8520
And what do they cost and do i get one
Old Mar 15, 2007 | 03:10 AM
mopowar's Avatar
mopowar
I believe the check valve to which they refer is, from the fan belt facing forward, directy backwards and to the right of the distributor. Trace the line back from the cruise control/ vent controltee
Old Mar 15, 2007 | 03:43 AM
ram51's Avatar
ram51
I had my AC rebuilt and it did the same thing it was a valve teethat the vacum lines connect to there's a little metal flap that got stuck when it gets dirty I blow air into it and fixed it till it got dirty again so I replaced it with a new one problem solved.
