New Mods for Me
Old Mar 17, 2007 | 09:10 PM
2 Marks's Avatar
2 Marks
Default New Mods for Me
Well I am up to three mods with a fourth on the way. First I started with Hyperteching for 87 octane on the 2001 5.2L. This was an improvement. Yesterday completed a Dynatech high flow cat and a Flowmaster Big Blcok 50 - all three inch in and out. I have had a chance to put some miles on and was very impressed pulling hills. Not much loader than stock, which I wanted.
The Fastman will be here in a week or so. Cant wait for the snow to go away so I can trailer a load and give it a real test.
Old Mar 18, 2007 | 02:52 AM
JohnnyRebs360's Avatar
JohnnyRebs360
Default RE: New Mods for Me
Well for your programer you might want to considering a 180* themostat. Air intake would be another good upgrade, I'm going to putan open element on soon insted of a K&N.
When you upgrade the engine performance you may want to upgrade the STOPING. Whooooooooo........big fella!
Old Mar 18, 2007 | 11:14 AM
2 Marks's Avatar
2 Marks
JR360, I have a 180 degree stat in the garage as well... waiting for warmer weather. I too think I am going the route of 14x3 for air intake. Sounds this the guys on the forum have had better experieinces for significantly less money.
How do you like your 3.92's?
Old Mar 18, 2007 | 02:02 PM
JohnnyRebs360
Well I just now put that 180* on thursday and my water & enginetemp has decreased a good 30 degrees, for my air cleaner I wanted not to big for interference with anything it will be a 10"x 2" Edlebrock#1208 and a K&N filter#1068 from summit racing. I'm also relocating my IAT sensor to the air filters base. I also thought about removing the side panels from the left&right off the front for more air into the engine bay. I may even put a cowl scoop on (2-3 inch).
My 3.92:1 is a good gear in my opion. In between the 3.55:1 streetand the 4.10:1 H.D. tow gears, the posi was installed by the former owner it's only in the rear. Its got a decent take off and a top speed.When it takes turns you can feel the twisting of the rear trying to pull out from under the frame. I don't need to get above 40mph in tight turns. I thinking about getting me some cross drilled/slotted rotors and hawk brake pads on.
.[sm=nxsmile.gif][sm=gears.gif]
Old Mar 18, 2007 | 02:53 PM
2 Marks's Avatar
2 Marks
I've got the 3.55's; made a mistake... should have found this site seven years ago. Been toying with 3.92's or 4.1's. I think the plan is to do all the easy mods then tell the wife I still need trailer pulling power... so I can get the gears.
