final decsion!
Old Mar 19, 2007 | 10:33 PM
dannthemann's Avatar
dannthemann
Default final decsion!
I am planning on getting a 3in. lift with a 285/55/20 tire, I thinks its about 32.4 in tall, and the wheels have a -15 offset,will they rub. Also any gear changes needed?
Old Mar 19, 2007 | 10:45 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: final decsion!
A 32.4" tire is going to look kinda small with 3" of lift. Shouldn't need to change gears though unless you really want some performance.
Old Mar 19, 2007 | 11:31 PM
dannthemann
what size tire do you guys think will look good with a 3in. lift?
Old Mar 19, 2007 | 11:33 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
34, 35 if you can squeeze it.
Old Mar 19, 2007 | 11:41 PM
lauren_24's Avatar
lauren_24
Unless you really wanted nice performance, you have to change gears! You can always change for some new performance parts.
Old Mar 20, 2007 | 12:00 AM
Silver_Dodge
At least 33", and 34" would be better. Not sure if you can stuff 35's with just 3" though. My tires are 32.8" (285/70/17), and sometimes I think they look a tad on the small size with my 3" lift. I wouldn't want to go any smaller, that's for sure. But the taller tire you go, the more you will wish you had gears.
Old Mar 20, 2007 | 01:07 AM
Ram_Sport's Avatar
Ram_Sport
see, im going w/ 285/75/16's cause i have 3.55 gears and its the best cost plan for me otherwise 34"ers and regear and all kinda other stuff, imo 33's on a 3' lift is sufficient,
Old Mar 20, 2007 | 01:29 AM
Socha_62's Avatar
Socha_62
I don't think you'll need gears. You probably have 3.55's and maybe 3.92's. Either will do find for a 33-35" tire unless you plan on doing alot of heavy towing.
Old Mar 20, 2007 | 01:39 AM
Silver_Dodge
If by fine you mean sluggish off the line and no low end torque, then ya, 3.55's are fine with 33's or 35's. Glad I have 4.10's with my 32.8 though.
Old Mar 20, 2007 | 02:04 AM
habeba86's Avatar
habeba86
I have 33's with 3.55's and I wish I had 4.10's...................If I jump up to 35" tires for my next set....I will have to re-gear, my o/d is almost useless as it is.
