pinging / rattleing noise
Old Mar 25, 2007 | 11:29 PM
echseman's Avatar
echseman
Default RE: pinging / rattleing noise
not sure.
Old Mar 26, 2007 | 04:29 AM
JarheadX's Avatar
JarheadX
are u sure its not the cat? I had a rattle and it was a bad cat, peices of it were broken off inside, so i gutted mine
that is what is in your cat, mine wasn't broken up that bad in there, but it was broken
Old Mar 26, 2007 | 11:12 AM
Magnumpwr16's Avatar
Magnumpwr16
From reading all of this it sounds as if it could be a wide range of problems. I wish I knew which problem my ram had, cause if it's the start of something big, I'd consider getting rid of it now. Mine has more of a metallic rattling, not a pinging,from under the hood. It only does it when a lot of gas is being fed to the engine, especially when I'm going up a hill, but sometimes on fast take off's. Please if anyone can narrow my problem down. Thanks.
Old Mar 26, 2007 | 11:13 AM
Magnumpwr16
Oh and I don't know if this helps, but I heard mention of premium gas helping this problem? As I said, I dont even know what the problem is, but I use regular 87 octane if that means anything.
Old Mar 26, 2007 | 07:22 PM
echseman's Avatar
echseman
yeah, i know wonce i start tearing it up, i will open up a whole can of worms. i know the bad idle is due to electronics issues, and the rattling/pinging turns out to be the kickdown cable. but last night my tranny started knocking. since the engine is running rough, it jacked up the bearings and probably chipped my gears. at the end of the week it will be better than new! haha.
Old Apr 7, 2007 | 02:51 PM
1997318Dr's Avatar
1997318Dr
prolly need some new lifters. i drove my pa's jeep wrangler the other day and that all you could hear in 2nd and 3rd..lol..its pretty new too like 2001
Old Apr 8, 2007 | 03:21 PM
MotoRider's Avatar
MotoRider
echseman: So the rattling/pinging whileaccelerating up hills was caused by the "kick down" cable? I have exactly the same issue and got excited when I saw this thread. Please clarify when you get a chance. Thank you!
Old Apr 8, 2007 | 03:45 PM
Tarner's Avatar
Tarner
ORIGINAL: ram51
Doesn't the Plenum Gasket cause a ping.
Yes it will cause the engine ping. My Ram had a bad ping under acceleration and while going up hills. After I replaced the plenum gasket it stopped. Now I just need find out why I can't get over 11 MPG Now.[:@]
