Best way to clean Fuel Injectors?
Old Mar 26, 2007 | 10:50 PM
Teggy_Boy's Avatar
Teggy_Boy
Default RE: Best way to clean Fuel Injectors?
Never said it did. But it will clean your intake, piston heads, valves, and TB (if the vacuum line permits). I was mainly trying to back up Sea-Foam as a product. I'm sorry it didn't 100% relate to the subject at hand, which is how to clean the injectors. Good luck
Old Mar 26, 2007 | 10:51 PM
xyzik's Avatar
xyzik
Will using plain water in a sonic cleaner damage the injectors?
With the cavitation process of a sonic cleaner what solvent is safe to use? seafoam? plain hardware solvent or those specialty detergents that is specifically made for a sonic cleaner, which is like simple green. ( I read somewhere that the caviation process is as hot as the sun temperature? is that correct?)
Old Mar 26, 2007 | 11:28 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: xyzik
Do not use water to clean the injectors. You sure as hell wouldn't use water to clean a carburetor or any other fuel related component, would you? [] Mineral spirits or any other solvent for cleaning parts in a parts washer. As soon as I can, I am going to repost the pics from my engine building thread so you can see the before/after process.
All of the people suggesting Seafoam need to know that it isn't going to do squat on a plugged injector.
Old Mar 26, 2007 | 11:43 PM
mcss8541's Avatar
mcss8541
Use it in that order (ie. 1st tank use the Techron, 2nd tank use the MOPAR fuel injector cleaner, etc?????????
Old Mar 27, 2007 | 11:42 AM
HankL's Avatar
HankL
Use any order you want.
Other good cleaners are:
LubroMoly Jectron (recommended by BMW and VW)
Redline SI-1
Yamaha Ring Free
Old Mar 27, 2007 | 03:06 PM
tdmopar59's Avatar
tdmopar59
ORIGINAL: HankL
The best cheap way I have found is to buy one bottle each of:
Techron Concentrate Plus
Mopar fuel injector cleaner
Napa Auto Parts 'Kleen' two bottle pack
and then put them in your next 4 tanks of gasoline.
For the highly effective but more expensive way
Steve Dulcich likes this machine:
http://www.asnu.com/asnu01.htm
which can clean and test 8 injectors at a time.
There is an added advantage to this, because after testing you can install the highest flowing injectors in cylinders 7 and 8, which in most 5.2/5.9 V8s need a richer mixture to keep from pinging.
where do you get these fluids are they easy to find?
Old Mar 27, 2007 | 07:44 PM
HankL's Avatar
HankL
Mopar fuel injector cleaner is at the dealership for about $7
Chevron Techron Plus at Chevron stations or Autozone for $10-12
Kleen 2 bottle set is at Napa Auto Parts for $14
Ring Free is at Yamaha outboard motor dealerships
Pep Boys usually has SI-1. BMW injector cleaner is also Jectron.
Old May 5, 2011 | 09:06 PM
J415's Avatar
J415
Bump TTT. I'm getting ready to install my air gap and wanted to know what's the best way to clean injectors.
Old May 5, 2011 | 09:28 PM
aim4squirrels's Avatar
aim4squirrels
If they are out of the engine, go with the ultra sonic cleaner. If in the engine, do as HankL suggested.
Old May 5, 2011 | 09:31 PM
BIGBIRD85's Avatar
BIGBIRD85
if they are out then get the jewlery cleaner thing (sonic something) fill it up with mineral spirits and let thing do its think. it cleans them real well!! then once a month run lucas fuel injector cleaner in your tank. i put it in mine when i pay the house payment
it dont have to be this one but you get the idea what im talking about. cheaper ones at wal-mart
http://www.sonicsonline.com/gemoro-u...y-cleaner.html
