Best way to clean Fuel Injectors?
Old May 5, 2011 | 10:07 PM
  #21
J415's Avatar
J415
Have you guys clean your injectors successfully with the jewelery cleaner? And yes, my FI's will be out since I have to swap them on to the new manifold.
Old May 5, 2011 | 10:20 PM
  #22
aim4squirrels's Avatar
aim4squirrels
I have had good luck with the ultra sonic cleaner.
Old May 5, 2011 | 10:37 PM
  #23
J415's Avatar
J415
Cool. So is there a certain process I need to follow?
Old May 6, 2011 | 06:56 PM
  #24
terribleswiss's Avatar
terribleswiss
i actually put a bottle of techron in my sonic cleaner, cleaned the injectors in it for 15 minutes and not an issue with them since
Old May 6, 2011 | 07:09 PM
  #25
aim4squirrels
That is what I use as well
Old May 6, 2011 | 08:03 PM
  #26
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by VWandDodge
You sure as hell wouldn't use water to clean a carburetor or any other fuel related component, would you? []
I use distilled water to clean carbs and throttle bodies myself. Brush any gunk off, drop 'em into some just-boiling distilled water, and let 'em cook for a half hour or so. Sometimes I'll add a splash of distilled white vinegar to make the water a bit more acid. The parts come out hot so the DW that remains evaporates away, and there's zero etching of the metal. Sometimes it takes a bit more brushing/wiping and another dip, but it works well.
I wouldn't clean injectors that way, though.
Old May 7, 2011 | 01:01 AM
  #27
tweeker909's Avatar
tweeker909
Best way is to send them in to someone like FIC so they can clean the inside by cycleing them on/off,change filter basket,pintle caps and viton o-rings. Jewelrey sonic cleaner only cleans the outside any benifits are from a cleaner basket not the gunk in the injector.
Old May 7, 2011 | 09:34 AM
  #28
aim4squirrels
You can open an injector with a 9 volt battery. Tape some wires to the injector prongs, then touch them to the terminals on a standard 9 volt. You could even do this a few times in the ultrasonic bath if so inclined. You could also get really fancy and buy a replacement injector harness to make swapping to the next injector easier. Just peel back a little insulation on the pigtail and tap the poles of the 9 volt. A small battery like that won't burn up the injector if it's left open for a while like an injector short in a truck would.
90% of the gunk is in the filter basket on the top of the injector anyway. The ultra sonic bath really does shake a crapload of the stuff out of the basket.
Sending them is absolutely the best way, but it's also the most expensive.
Old May 7, 2011 | 12:57 PM
  #29
J415's Avatar
J415
Very true, I'm just not looking to spend upwards of $25 per injector (x8 injectors) to get these cleaned.
Old Jan 29, 2020 | 08:21 AM
  #30
zezo's Avatar
zezo
Iused white spirit in my car it work fine
