Problem
Old Mar 27, 2007 | 02:03 AM
66BIRD's Avatar
66BIRD
Default Problem
I have a 99 Dodge sport with a prob. thats got me stumped don't know if it is a relay or a worn ignition switch but it seems that accessorys won't shut off mirrors,radio'signals and all that is there a relay that could bestuck or could the ignition switch be worn out from plowing with the keys in it?
Old Mar 31, 2007 | 03:44 PM
94ram15004x4's Avatar
94ram15004x4
Default RE: Problem
switch it with a nother realy in the box to see if it fixes the problem. quick and simple. if not you know your picking up power from somewhere else. try pulling the ingition fuses and see if that fixes the problem. i would beleave it would be in your key switch then
Old Mar 31, 2007 | 10:01 PM
Rammer's Avatar
Rammer
Default RE: Problem
I had the same problem with my truck, same syptoms. It ended up being the daytime running light module. Got it replaced and everything worked fine after that
