Temperature ?
So my truck started running at like 130......it will never get into operating temp on the gauge anymore, it will go upto like 135if im running like 80 on the interstate. No dummy lights on, and it seems to run fine. What could be goin on?
thermostat has failed, and is stuck open. if you've flushed coolant recently its not necessary to do it again.
if you haven't its a good idea. btw, i found drain plugs in my 01 318 block that are handy, one on each side. a lot of coolant (and rust) comes out of the block.
just a thought, its possble you could have a bad temperature sending unit. you can check that by feeling the top radiator hose. normal operating temperature of about 170-180 is too hot to hold onto.
so if your gage is reading low and the top hose is real hot, this would indicate you have a bad sending unit.
if you gage is reading low and the top rad hose is only mildly warm, your thermostat is stuck open.
Trending Topics
ORIGINAL: hilliad
Where are the drain plugs you found located?
