B&G Flash a NOGO
Old Mar 30, 2007 | 02:03 PM
TMS Bill's Avatar
TMS Bill
Default RE: B&G Flash a NOGO
Like popping the clutch on a stick. Rev it up in N (wouldn't go much over 1500-2000 rpm) and drop it into drive. Don't personally recommend it (wait ... you've got a bulletproof tranny, right). Dunno ... might work. I'd look for a REASON for the TCC to be engaged first (grounded signal wire, incorrectly installed TC, hydraulic pressure on the engagement system ... hell ... the TC could be bad) but it's worth a try.
Old Mar 31, 2007 | 12:39 AM
kikidbird's Avatar
kikidbird
I have tried that. I had to pump the gas pedal to get out in reverse, then I had to pump it again in drive. It feels like there is a rev limitter, doesnt let me go fast or high rpm. If I jack up the rear end, it drives and shifts well, up to 75mph. The minute I step on the brakes, she starts to stumble then stalls out.
Old Mar 31, 2007 | 01:35 AM
TMS Bill's Avatar
TMS Bill
Sounds more and more like the TCC is engaged.
Old Apr 3, 2007 | 12:53 AM
kikidbird's Avatar
kikidbird
Where is the TCC located? I have checked fuel pressure and its at 60psi. My vaccum is low, under 14inmg. What are the specs for fuel pressure and manifold vaccum? I was looking into installing a vaccum canister. I have read that installing a large cam, requires a vaccum canister.
Old Apr 3, 2007 | 01:41 AM
TMS Bill's Avatar
TMS Bill
Your low vacuum is probably due to the cam you're running. The TCC is the Torque Converter Clutch ... it's inside the torque converter. Your fuel pressure actually sounds pretty high.
Old Apr 3, 2007 | 02:33 AM
kikidbird's Avatar
kikidbird
Im going to try a vacuum canister, see if it helps. The torque converter was replaced, so I dont think its the torque converter. Any other Ideas? In park, I rev it up to 1500-2000 rpm then its starts to cut off. I dont think the torque converter has anything to do with it. It could also be a combination of things.
Old Apr 3, 2007 | 07:16 PM
TMS Bill's Avatar
TMS Bill
Thought the TC was replaced BEFORE you started having this trouble.
Old Apr 4, 2007 | 01:30 AM
spaz_22's Avatar
spaz_22
hum.....i'm pretty sure the tcc soleniod is located on the valvebody of the tranny.....that's were it is on most trannies....and i'm pretty sure it's the same on our trans
Old Apr 4, 2007 | 03:50 AM
kikidbird's Avatar
kikidbird
I sent out the torque converter to have it done to the specs I wanted. For some reason I feel it was not done right. I installed a vacuum canister and it didn't help. Im looking into pulling the engine and replacing the cam and torque converter.
Old Apr 4, 2007 | 04:35 AM
spaz_22's Avatar
spaz_22
i still think it's the soleniod in the valve body....
