fix for collapsing fan shroud
Old Feb 10, 2008 | 08:20 PM
dhvaughan's Avatar
dhvaughan
Default fix for collapsing sagging fan shroud
my fan shroud would not stay latched onto the radiator due to warpage. three little screws keep it locked in. drill pilot holes to prevent the plastic from breaking.
Old Feb 10, 2008 | 08:24 PM
TheForce55555's Avatar
TheForce55555
Default RE: fix for collapsing fan shroud
That looks like that could be hazardous to the rad...
after awhile it looks like they would wear into the aluminum and cause a leak
Old Feb 10, 2008 | 08:32 PM
dhvaughan's Avatar
dhvaughan
that's the top support frame. it won't hurt it.
Old Feb 10, 2008 | 08:40 PM
padodgeram's Avatar
padodgeram
as long as it works , thats all that matters...
Old Feb 10, 2008 | 08:47 PM
Mowhawk's Avatar
Mowhawk
Pretty clever idea, good on ya.
Old Feb 10, 2008 | 08:59 PM
nolazach's Avatar
nolazach
I wonder if there isn't some kind of clip you could buy or fab up to fix this solution.
The radiator has holes that could accept clips, you can see it in the second picture.
Maybe some nice fabricator could make some up, make good money selling them on ebay and then give me a pair for the idea, because mine sags too.
I guess I could stick another screw were it don't go, I had one sticking out my battery terminal for months.[&:]
Old Feb 10, 2008 | 10:08 PM
CPTAFW163's Avatar
CPTAFW163
Thanks DH, i have the same problem. Once i fix the fire damage, then i will hit up my fan shroud.
Old Feb 10, 2008 | 10:27 PM
Mowhawk's Avatar
Mowhawk
Have you noticed any screw movement from vibrations?
Old Feb 10, 2008 | 10:58 PM
Houston4x4's Avatar
Houston4x4
I can fab clips that would work. Mine sags a little in the middle. I'll add that to my list and let the board know what I came up with.
Old Feb 11, 2008 | 07:26 AM
dhvaughan's Avatar
dhvaughan
ORIGINAL: Mowhawk
no. its locked in tighter'n dick's hat band.
