Limit Straps installed.
Old Mar 3, 2009 | 08:20 PM
Viper37's Avatar
Viper37
Default Limit Straps installed.
After a cut and adjustment on my drivers side, my limit straps are installed on both sides. Pictures:
The welds are beautiful, but I covered them with rubberized undercoating. That's what the bubbly looking stuff is.
I can pound over huge bumps at 40mph now and not hear a damn thing from the suspension.
Limit Straps = Win.
Old Mar 3, 2009 | 08:36 PM
Acapalic's Avatar
Acapalic
I = Susspension newb. What exactly is that strap really preventing?
Old Mar 3, 2009 | 08:37 PM
MAJohns's Avatar
MAJohns
nice i like it i might do it eventualy but what i like the most is the nice @$$ in the second pic!!! lol
Old Mar 3, 2009 | 09:25 PM
olyelr's Avatar
olyelr
Over extension of the suspension.
Nice job. I need to get me a set of those. Ever since I have been running without the sway bar I have been worried about leaving the ground in 4 wheel drive, as it now droops enough to bind the front shaft. That would be a doozy. Where'd you get those?
And dayyyyyyyyam, nice workshop ya got there.
Old Mar 3, 2009 | 09:47 PM
Kindschi's Avatar
Kindschi
Limit straps on a 4x2, exactly what kinda bumps you been running over that stress out your suspension? Neat mod none the less, we have the same thing on our mud trucks but we use some thick thick thick chains.
Old Mar 3, 2009 | 10:05 PM
helms's Avatar
helms
i like them.. good idea, good work
Old Mar 3, 2009 | 10:06 PM
01dabram20's Avatar
01dabram20
nice work area. is that a nova or something back there?
Old Mar 3, 2009 | 10:18 PM
95MaroonMonster's Avatar
95MaroonMonster
nice welding job
but that sandrail in the background gave me a hard on
Old Mar 3, 2009 | 11:46 PM
notanexit7's Avatar
notanexit7
what kind of shocks are those?? i'm doing a leveling kit, 2in in the front 1in in the rear, and i cant find longer shocks that are for 2wd. does it even matter if its only for 4wd?
Old Mar 4, 2009 | 12:02 AM
Viper37's Avatar
Viper37
ORW, I bought them Locally. They are Beard 3 ply straps, they can be sourced all over the internet. SoCal has a ****load of off road stores because of all the desert racing out here.
My lift altered the geometry of my suspension. I ground the edges of my bump stops to give me another inch of travel, then limited them there. I pre-run out in the desert, and sometimes run the Prim and Glamis Courses.
There is a 4 runner, multiple quads and bikes, jet ski, 70 Challenger, Manx, sandrail and a bunch of other stuff we have in there.
The Manx up front there was getting worked on because we're installing long travel suspension to it. Should have about 14 inches when we're done.
I'm currently in the process of designing bolt on long travel for my truck. I should have about 18 inches of travel, with only a hoop and minimal engine cage. I'll be running a 35" tire by then. Locked rear and deavers as well.
The 4 runner there is getting a supercharged 350 and long travel as well.
We're desert people, we pre-run.
Those are procomp 9000's. Great nitrogen filled shock. They are designed for +2 inches of lift. Longer 2wd shocks are all over the place, just look a bit harder. 4WD shocks will not fit 2x4's btw.
People on this forum are deadset that 2wd trucks cannot offroad, however where I live, you will rarely see a 4x4 in the desert. In fact, most built trophy trucks are 2WD.
