Grill Options
Old Mar 9, 2009 | 11:35 PM
Laramie1997's Avatar
Laramie1997
Default Grill Options
OK, so today I am driving down the road, and I see my bug deflector kinda flopping in the wind.
I pull over, and see that there is this very large crack going down the upper left hand corner of the grill.
I have some thoughts on what to do on this, and I have decided to try to paint it to match my truck.
I did do a search, but didn't find anything that covered doing something like this.
here is a pic of what I am thinking about doing
It wont be reflective like the one in the pic.
Call it a hicker billy fix, but I plan on taking the "Chrome" foil off the plastic frame to paint it. Has anyone ever taken the chrome off of the grill like that?
I have some very good white epoxy that I plan on using to patch the crack back up with, and then I will sand it back down to look right.
My questions: 1. What is the easiest way to pull the "Chrome" Foil off that grill?
2. What are the recommended paint prep instructions to prep the plastic?
3. I think I will use automotive paint to match the rest of the truck Will that type of paint hold?
4. What primer would work the best?
Let me know what you all think.
Thanks
EDIT: AIM if you see this, I did this on my laptop touchy pad too
Old Mar 9, 2009 | 11:44 PM
TMS Bill's Avatar
TMS Bill
I bet a fine grit sanding sponge will make short work of that "chrome".
Old Mar 9, 2009 | 11:46 PM
JackJ's Avatar
JackJ
Remove all chrome, chrome is the work of the devil.
Old Mar 9, 2009 | 11:49 PM
Laramie1997
lmao, I like chrome, but only when it is actually chrome. This Junk that I have on my grill now is like a real thick foil type crap. part of it should come off pretty quickly since it isnt adhered to the plastic anymore.
Old Mar 10, 2009 | 12:00 AM
JackJ's Avatar
JackJ
Fine grit all you can off, and use some MIL-H-83282 aka hydraulic fluid, if it is a metal grill. if it plastic be carefull and don't reomve to much material or is may not fit properly.
Old Mar 10, 2009 | 06:46 AM
PurplDodge's Avatar
PurplDodge
Paint it orange!
Old Mar 10, 2009 | 09:22 AM
Laramie1997
purpl, I like things on my truck to match
Old Mar 10, 2009 | 09:49 AM
Silver_Dodge's Avatar
Silver_Dodge
and to look good.
Old Mar 10, 2009 | 10:58 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Thats a nice red! You should paint the hole truck that red!
Old Mar 10, 2009 | 11:50 AM
Viper37's Avatar
Viper37
The reason it shines like that is because he simply selected the chromed area in Photoshop and bumped the levels. Read his original post.
