Dist Cap really behind the engine??
Old Nov 6, 2009 | 06:30 PM
Mudshack's Avatar
Mudshack
Default Dist Cap really behind the engine??
Is it really? Behind the TB and under the body, on the back of the engine? What an inconvenient place. Please say it ain't so. Any tips on where to sit in the engine compartment to replace your wires? lol
Old Nov 6, 2009 | 07:29 PM
WScott1500's Avatar
WScott1500
Yeah, that's where it's at. I sat on the radiator support and twisted sideways leaning towards the distributor. It might have been worth a gasket to just pull the TB. 3 weeks later I did the plenum gasket and actually had a chance to see what I was working on by feel before.
Old Nov 6, 2009 | 07:37 PM
surferguy12's Avatar
surferguy12
ya same with me lol, the distributor cap is a b!tch to get towhen you are changing out your wires, i used a step stool to reach at first then just got in and sat on the side, passenger side is a lot easier tho
good luck, lol
p.s. make sure engine is cooled before changin wires, lol learned that the hard way
Old Nov 6, 2009 | 10:03 PM
95RAM360's Avatar
95RAM360
its actually not that bad when you get the TB off. i didnt have a problem. but i re-did it when i did my plenum because it was smack dab in front of me
Old Nov 6, 2009 | 10:25 PM
nathangfnd's Avatar
nathangfnd
easy way to do it would be to disconnect steering shaft and some wires along with fan shroud then simpply take 6 bolts out and jack up the body.
Hey while your at it put a body lift on
Old Nov 7, 2009 | 12:44 AM
lastrights's Avatar
lastrights
just take off the intake and throttle body and stand on a high stool and lean thats what i did , good thing its a once in a while thing lol... also if you do plenum its always a good idea to do a tune up cause of east access
Old Nov 7, 2009 | 02:21 AM
estech2's Avatar
estech2
You guys must have the stock intake, I just sit in the passenger side of the engine compartment with the aircleaner removed, lean over the valve cover and I get to mine no problem!
Old Nov 7, 2009 | 02:31 AM
dakotas ram's Avatar
dakotas ram
ford was pretty smart with their front dizzys
Old Nov 7, 2009 | 09:03 AM
moparama's Avatar
moparama
i just do it when my engines out lol
Old Nov 7, 2009 | 12:32 PM
cmckenna's Avatar
cmckenna
It's cake to get at. Just lay something soft over the radiator / fan shroud and lay on your belly on that. Remove the TB and she's right there. You will have to disconnect the purge valve and get it out of the way. It makes it easier to access.
So, it's really super easy to get at once you have done it a few times. The stock keg style intake is high so, it's almost impossible with the TB left on.
So, disconnect the neg cable, disconnect the three sensor harnesses at the TB, disconnect the vac line to the TB, disconnect the throttle cables at the TB first. Then, using a small screwdriver, pull the plastic tang out of the hole to release the front cable. The one in the rear uses two push style tangs on the side facing the front of the vehicle. Push it down on the top and up on the bottom to release it from the throttle plate. Slide the cable out towards the firewall.
Loosen the four fasteners that hold the TB onto the manifold. Remove the TB and set aside. Place a shop rag into the opening to prevent anything from falling into the intake.
Next, disconnect the purge solenoid valve. It is black, it is to the right side and has two vac lines and one harness. Remove those and slide the valve off the holder by rocking it while pulling up on it. To install it, simply spray some oil into the rubber sleeve and on the mount- it will slide right on.
You will now have open range to work in the rear of the engine. I have even changed them out without removing the TB when I first started out. With the hughes Intake, it sits lower and, I can leave the TB on and still get to it w/o a problem. I also relocated my x-over line to the front of the rails to allow even more room back there.
When reinstalling the TB, torque the fasteners to 19 ft pounds. It can also be done by hand, by feel too so long as it's evenly tightened all the way around and that there are no leaks.
You may also want to clean you TB while your at it. To do that, simply remove all the sensors and gasket from the TB and spray and brush it down using brake cleaner or, acetone, mineral spirits, denatured alcohol or turpentine. Brush it clean until all the black, sooty material is off 100%. Give it a final rinse, place a new gasket on there, put the sensors back on and install it onto the manifold and your good as new.
Last edited by cmckenna; Nov 7, 2009 at 12:40 PM. Reason: Torque spec. and TB cleaning recommended
