97 5.2 -Stalls during Deceleration and Idle
Old Jan 6, 2010 | 09:25 PM
sbandd2's Avatar
sbandd2
Unhappy 97 5.2 -Stalls during Deceleration and Idle
This just happened less than 2 hours ago, while exiting the freeway and I just about wrecked my truck due to the engine dieing when I slowed down to exit. Never had this happen before, managed to get the truck to the bottom of the ramp, put it in neutral and it started, seemed fine until I stopped at the next light and it died again. There wasn't any engine light or any other signs that there was a problem - other than I had to keep one foot on the gas and the other on the brake to keep it running at the light.
Got it home, let it sit for a while to cool off and checked it for a loose coil wire ect..., didn't fine any, so I started it and it appeared to be fine, at idle it maintain proper idle, reached operating temp (200) per the gage and no indication that there was a problem. I took the wife out for dinner and it started again.
Anyone have an idea as to what is going on?
Don
Old Jan 6, 2010 | 09:29 PM
dhvaughan's Avatar
dhvaughan
are you getting any check engine lights or codes. and if its otherwise running fine. and if you can keep it running by applying a little gas pedal pressure,
its most likely the IAC, but it could also be the TPS.
both are common parts and each costs about $40-50.
Old Jan 6, 2010 | 09:31 PM
1998ram5.9's Avatar
1998ram5.9
id replace the distributor cap and rotor, the electrodes in there might be almost gone.Also id look into maybe a clogged fuel filter or bad fuel pump.
Old Jan 6, 2010 | 09:43 PM
91xjgawes's Avatar
91xjgawes
with all this cold weather watch the battery too...
But sounds similar to an IAC problem IMO...
Old Jan 7, 2010 | 06:27 PM
sbandd2's Avatar
sbandd2
No engine light - as for the codes, I'll have to check them manually as I don't have a reader. Will do after dinner
Old Jan 7, 2010 | 06:28 PM
sbandd2's Avatar
sbandd2
Battery is good to go - will have to figure out how to check the IAC?
Old Jan 7, 2010 | 06:34 PM
sbandd2's Avatar
sbandd2
Distributer cap, plugs, wires were done less tha 3K/5 months ago, and fuel filter was about 10 months ago.
Truck has 236K on it and is driven daily, I keep it regulary serviced and tuned up.
That I why I sumped with the way it is behaving.
This summer, the CAT was replaced and changed both O2 sensors, full tune up and it was running strong, better than it has in the past - drove it down to FL from Michigan to do a 6 wk job down there and avg 18 MPG.
Old Jan 8, 2010 | 01:55 AM
Rammanator's Avatar
Rammanator
So I've got a similar prob, mine only stalls in reverse after I take my foot of the gas. In drive it's perfect ????????
Old Jan 8, 2010 | 03:26 AM
J415's Avatar
J415
With the truck on, (If you can get it to do so) wiggle the coil harness around and see if it cuts out. Happened to me and damn near gave me a heart attack.
Old Jan 10, 2010 | 11:22 AM
sbandd2's Avatar
sbandd2
Checked for codes but none show up? Checked more than once just to be sure - It seems problem does occurs after engine temp reaches 180 and computer goes into the Closed Loop Cycle. Dealership book describes how the different cycles work and where the computer (PCM) receives it signals from, one common item is the Engine Coolant Temp sensor. Since this is the low cost item on the list, I just might replace that item and then work my way up to the Idle air control (IAC) motor and TPS. to me this might be the best place to start cause it's fine until I reach temp and the PCM uses the temp switch to tell the injectors and timing where to be.
As for the coil wire, I'll check that out as soon as I find my ignition plies, that way I won't get fried like the other gent described -felt like a heart attack when it lit him up
