whining when in reverse
Old Dec 7, 2010 | 12:01 PM
donnys97ram's Avatar
donnys97ram
Default whining when in reverse
My '97 Ram 4X4 began whining/squilling when backing up in 2wd, is worse uphill. Any ideas?
Old Dec 7, 2010 | 02:17 PM
97r/tram's Avatar
97r/tram
It's called reverse moan. Just leave it alone. Usually only when cold right?
Old Dec 7, 2010 | 08:40 PM
Grayfox0092's Avatar
Grayfox0092
Phew. Good to know this is nothing to worry about. This started on mine recently, but I live in Buffalo NY and lately it's been freezing here so that must be it.
My rig has 46,160 right now, so tranny problems this early would kill me.
Old Dec 7, 2010 | 10:14 PM
aim4squirrels's Avatar
aim4squirrels
The manual valve in the trans rattles/buzzes in its chamber in the valve body as cold fluid moves by it. Mine does the same thing, usually goes away when the trans fluid gets to about 60*. Totally normal for a Dodge. Loud and scary as hell the first few times you hear it each year.
Old Dec 8, 2010 | 12:35 PM
donnys97ram
Thanks!!!! Nice to know it is normal for Dodge (I guess).
Old Dec 8, 2010 | 01:08 PM
aim4squirrels
Well I should clarify, its normal for the A518 transmission, not ALL Dodge vehicles.
Old Dec 8, 2010 | 01:09 PM
candymancan's Avatar
candymancan
Normal IMO
Alot of cars do this
Old Dec 9, 2010 | 01:39 PM
champion88's Avatar
champion88
Mine was doing that when it was low on fluid, make sure you check it in neutral. After I added some fluid it's quiet now.
Old Dec 10, 2010 | 01:23 PM
donnys97ram
Thanks, fluid level is good.
