transmission part # questions.
Old Jan 30, 2011 | 09:47 AM
redneck_ram's Avatar
redneck_ram
Default transmission part # questions.
hey guys, im going to be buying a new trans shift solenoid and over drive solenoid, but wittrans.com has 2 different part numbers for both, and i need some help to figure out which ones i need. here are the part numbers and the link to them.
Governor pressure sensor: https://www.wittrans.com/SchematicPa...8&LinkCode=415
00-01 d12415c
Governor pressure solenoid: https://www.wittrans.com/SchematicPa...8&LinkCode=432
00-01 12432a
00-01 a12432a
00-01 a12432ak
00-01 d12432a
00-01 r12432a
Overdrive and lock-up solenoid: https://www.wittrans.com/SchematicPa...8&LinkCode=420
00-01 d12420c
00-01 r12420c
so those are the part numbers, i dont know which ones to get except for the pressure sensor. any help and guidance is appreciated. thanks.
Old Jan 30, 2011 | 09:55 AM
D12415C Sensor.
For the pressure solenoid, probably gonna have to call them, and ask what the differences are, if any......
For the O/D and lockup solenoids, need to take a look at what connector you currently have, and then order the one with the same type.
Old Jan 30, 2011 | 10:07 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Although more expensive, I got mine from PATC. They don't make it near as confusing. I got the Gov. solenoid locally, and the OD/TC solenoids and pressure sensor as a kit from PATC, #K22954C BTW, I know what you are fixing, you'll need the gov body from the original trans. The pressure sensor mounts differently.
Old Jan 30, 2011 | 05:42 PM
redneck_ram
what does the gov body look like? i dont have my original trans anymore. i was hoping it was going to be a quick and easy swap out. now it sounds like its going to be more fun than i thought.
Old Jan 30, 2011 | 05:59 PM
xjarhead69's Avatar
xjarhead69
From their website
Parts # Legend
General Prefixes:
B - Borg Warner
D - OEM Dealer Part
U - Good Used Part
Part Specific Prefixes:
None
º ATSG Tech Manuals
º New Bushings, Gaskets, O-Rings, Metal Clad Seals, Modulators, Sealing Rings, Steels, Washers and Bearings.
º Raybestos Frictions
º Rebuilt Hard Parts
º Relined Bands
º Rostra Electrical Parts
º Sealed Power Filters
º TTK or Precision Overhaul Kits
º Kits w/Raybestos Frictions
A
º Alto or Allomatic Frictions
º ATRA Tech Manuals
º New Electrical Parts, Hard Parts and Valve Body Kits
º Off Shore for Bushings, Filters, Metal Clad Seals and Sealing Rings
º Raybestos Bands
º Kits w/Alto or Allomatic Frictions
E
º Filter Teck Filters
N
º Dynax Frictions
º New Bands
º Kits w/Dynax Frictions
R
º Rebuilt Electrical Parts
S
º Sonnax Hard Parts and Bushings
º Superior Valve Body Kits
T
º TeckPak Bushings, Electrical Parts and Modulators
º Transel Tech Manuals
º TransGo Valve Body Kits
º TransTec Overhaul Kits
This should clear it up for you.
I would go with D12432A
Dave
Old Jan 30, 2011 | 09:21 PM
redneck_ram
well im gonna call wit in the morn. anyone else have any other input?
Old Jan 31, 2011 | 11:16 AM
dodgeboy1979's Avatar
dodgeboy1979
if you are changing your gov pressure solenoid do the GM conversion kit on it as well.
Old Jan 31, 2011 | 01:11 PM
stands2p's Avatar
stands2p
Not worth the money when borg warner has a new governor pressure solenoid offering #50185.its bigger by far, wont flood-out at 6k wot,is much more reliable and most important it is direct fit.all at a 3rd of the cost of that kit.they should have it transtar # 12432A
http://www.transtar1.com/
Old Jan 31, 2011 | 01:57 PM
If that part is also self-cleaning, like the GM part, that would definitely make it worth while.
Old Jan 31, 2011 | 02:24 PM
zman17's Avatar
zman17
I also used the BW solenoid. Here is the info it came with.
https://dodgeforum.com/forum/2nd-gen...noid-info.html
