belt Squealing
Old Feb 5, 2011 | 11:26 AM
Silver_Dodge's Avatar
Silver_Dodge
I once had that happen, and it was the gator back belt. As soon as I switched to an OEM belt, it worked fine from that point on.
Old Feb 5, 2011 | 12:49 PM
king_moaoe's Avatar
king_moaoe
humm, so think napa would have better belts? i bought my dayco from autozone
Old Feb 5, 2011 | 12:53 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I use Gates myself. I would get a wire brush and some break clean to clean things up before installing a new belt. The pad you used won't get down into the ribs.
Old Feb 5, 2011 | 03:27 PM
Sheriff420's Avatar
Sheriff420
The comments about Dayco being a problem is funny because I've had my Dayco belt (the lifetime warranty one that's about $40) for a couple years and it doesn't make a peep.
The belt tensioner on the other hand used to click and clack for quite a while before I finally got a new one.
Old Feb 5, 2011 | 04:52 PM
CPTAFW163's Avatar
CPTAFW163
Check these vids. The pulley system might be out of alignment at the water pump or steering pump:
First, you need to see if it is a chirp or squeal
Belt chirp caused by pulley misalignment: 2nd gen ram used!!!
http://www.youtube.com/watch?v=X9qMt...eature=related
belt squeal caused by bad pulley:
http://www.youtube.com/watch?v=sli3FnPfdQ4
Belt noise causes and solutions:
http://www.youtube.com/watch?v=cW_wp...eature=related
