quick rearend question
Old May 20, 2011 | 09:20 PM
kejobe's Avatar
kejobe
Default quick rearend question
I have a 2001 1500 4x4. I came across a rearend out of a '98 that has a lsd. Will a 98 fit without any problems or are there differences between them? I'm pretty sure there all the same. They both have the 355 gearing.
Old May 20, 2011 | 10:09 PM
Should bolt right up. Might be a difference in connectors on the rear wheel speed sensor though, and possibly E-brake cables...... aside from that, its the same axle.
Old May 20, 2011 | 11:31 PM
kejobe's Avatar
kejobe
Thats bout what i was thinkin. Thanks.
Old May 21, 2011 | 12:15 PM
dhvaughan's Avatar
dhvaughan
should be fine.
double check the pinion yoke for round flange vs u-bolts. worst case swap the yoke.
Old May 21, 2011 | 12:23 PM
kejobe's Avatar
kejobe
Originally Posted by dhvaughan
should be fine.
Didn't think of that part.
Old May 21, 2011 | 01:45 PM
dhvaughan's Avatar
dhvaughan
this should answer any question you might have about a rear end.
Old May 21, 2011 | 03:50 PM
Very nice, do you know where I can pick one of those up? I think it would look really good in my truck.
Old May 21, 2011 | 06:49 PM
97tn4x4's Avatar
97tn4x4
I'd like one too lol!
Old May 21, 2011 | 11:06 PM
kejobe's Avatar
kejobe
After some research, ive come to the conclusion that this rear would get me into alot of trouble with the wife , and the factory lsd's dont seem to hold up well. So, i think im just goin to lock the one one in the truck.
Old May 22, 2011 | 02:44 AM
97tn4x4's Avatar
97tn4x4
The factory lsd's aren't as bad as everybody makes them out to be. They aren't great and they can have problems. I just had mine rebuilt when I got my gears installed and it worked great this weekend. Climbing some hills with one back tire off the ground and both tires were pulling. I was truly amazed.
