power lock conversion
Old Sep 3, 2011 | 01:51 PM
tatitup8's Avatar
tatitup8
Default power lock conversion
alrighty guru's.. got my 99 dodge ram crying to switch his manual locks/windows with a 2000.. im going to the donor's truck on monday. he said if i do the work, i can have EVERYTHING for $20.. good deal huh? so im just wanting to know what all i need to grab.. any and all help is appreciated! thank you
Old Sep 3, 2011 | 03:51 PM
Check your truck, there should be some lonely connectors in the cab-side door frames for the power accessories. If there aren't grab that harness from the donor truck as well.
Old Sep 3, 2011 | 04:45 PM
tatitup8's Avatar
tatitup8
Ill grab everything inside the door, wether I have it or not. But I'm mainly concerned with what's Not in the door. I looked under the dash and didnt see any lonely connectors. Where do they hook up and what not?
Old Sep 3, 2011 | 04:52 PM
zman17's Avatar
zman17
Retired Moderator - RIP
They hook up to the plug that's inside the rubber boot. If they are not pre wired, this isn't as easy as it seems. I suggest you look at the wiring diagrams in the FSM
Old Sep 4, 2011 | 01:48 AM
tatitup8's Avatar
tatitup8
looked in the FSM and can't really find anything that helps me on that.. :/
Old Sep 4, 2011 | 06:38 AM
Novarider's Avatar
Novarider
Would be easier to just replace the doors
Old Sep 4, 2011 | 08:37 AM
The doors will have the harnesses in them, yeah. (the doors that actually have power windows/locks) but, if the body side wiring harness isn't there, the job becomes a bit more difficult. If the connectors on the body side aren't stuffed in there somewhere, then you have to deal with that as well. Not exactly a minor undertaking.
Old Sep 4, 2011 | 10:03 AM
tatitup8's Avatar
tatitup8
So my truck doesn't have em.. Lol where do all the harnesses and clips hook up to under the dash?
Old Sep 4, 2011 | 11:03 AM
Everywhere........
Old Sep 4, 2011 | 11:36 AM
zman17's Avatar
zman17
LOL.... ^ All the info you need to say the hell with it, "is in" the FSM.
