what specific size tire do I need?
Old Oct 10, 2012 | 03:04 PM
Kasper William Eriksen's Avatar
Default what specific size tire do I need?
Hey Y'all!
I want to run 35'' tires on my 2001 dodge ram 1500 4x4 off road package, I am looking to order my tires online, but I am not sure what the full tire size will be.
The truck has the standard off road rims 17'' and obviously the tire size will be 35'' but what about rim width?
I know this is kinda of a retard question, but I just need some quick help please!
Appreciate it yall!
Old Oct 10, 2012 | 03:09 PM
Thornloe Pride's Avatar
Thornloe Pride
Pretty sure you are lookin at a 315/70/17
Old Oct 10, 2012 | 03:13 PM
ok, are you sure man? haha cause my old man offered me a new pair of tires cause he gets a good deal somewhere online, and I only have one shot
Jimythefan's Avatar
Jimythefan
Something in the 315/70-17 range will fit your factory rims. Ideally 35's should go on a 8.5 to 10 inch rim. But they'll work on an 8 inch.
Old Oct 10, 2012 | 03:50 PM
dlyter09's Avatar
dlyter09
Clearing those 35s on stock rims might not work.. Probably have a little bit of rubbing...Then you get into the whole gearing issues....
Old Oct 11, 2012 | 01:17 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Backspacing will be a problem in addition to not clearing the fender well with only the ORE lift. You can run 33s with very minor issue, but I'd recommend 4.5" backspaced wheels (minimum), which will result in just a kissing of the inner fender on the plastic at roughly 90% of full turn. Why....b/c I ran that setup for about 5-6 years.
35s will need a comfortable 5" lift, which can be done by a full kit or a budget one.
The guys above are citing 315 tires. Those are metric and is 315mm width = 12.4ish" If a tire is listed as 35x12.5x17 then it is 12.5" wide. Now if you don't know, not all tires actually measure true to those dimensions. For example BFGs a/t typically run quite short (e.g., 35" when installed results in 33.5"ish). Also, changing tire size will impact your speedo unless you calibrate it with a tuner or a shop.
Good luck soak all this up, which I certainly have not covered everything.
Old Oct 11, 2012 | 06:36 AM
so what would y'all recommend I do guys?
I was going to add a spacer in the front to get it leveled at little bit higher there. But what size tires and what kind for that sake? I was thinking some bf Goodrich all terrains or wrangler goodyear off road kind of tire!
Old Oct 11, 2012 | 09:06 AM
Default Lift/leveling kit for dodge Ram with Off road package?
Hey Y'all!!
I have a 2001 dodge ram 1500 4x4 Off road package, And I would like to increase the riding hight in the front additional to the 2'' lift the off road package delivers.
I have considered either a 2,5'' leveling kit from Rough country, or the topgunz customized 3'' blocks. Would either one of them work, and and in addition to the blocks, would I need to replace my shocks with either one?
Y'alls help is greatly appreciated! Thank you!
Old Oct 11, 2012 | 11:03 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Your first thread is related to this and already has responses. This topic is not unique from the first and hopefully a moderator will merge this with the other.
https://dodgeforum.com/forum/2nd-gen...do-i-need.html
Old Oct 11, 2012 | 11:06 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
