View Poll Results: What oil are you running in your motor?
Mobil 1
17
32.08%
Royal Purple
2
3.77%
Amsoil
4
7.55%
Valvoline Full Synthetic
6
11.32%
Pennzoil Synthetic
6
11.32%
Castro Synthetic
3
5.66%
Quaker State 4x4
2
3.77%
Havoline Synthetic
0
0%
Other Full Synthetic
4
7.55%
Dealership special
2
3.77%
Synthetic Blend (specify in a post)
1
1.89%
Conventional (dino) oil (specify in a post)
6
11.32%
Voters: 53. You may not vote on this poll
Motor Oil
Old 02-27-2009, 08:24 PM
object16's Avatar
object16
object16 is offline
2 parts MotorCraft 5w20 semi with one part QS 5w30 synthetic.
this yields a 5w23 oil, just slightly more robust that a 20 weight, but still with good cold flow properties.
Old 03-05-2009, 01:34 PM
luvmydak's Avatar
luvmydak
luvmydak is offline
Used to run Royal Purple, too expensive to continue, switched to Mobil 1. For a savings of almost $47 for a 6pack it was a non brainer. Mobil 1 is an excellent oil.
Old 03-07-2009, 02:29 AM
object16's Avatar
object16
object16 is offline
ANY SM 5Wxx conventional oil now is a group II, even Bozo the Clown Brand, which is way better than any oil of 15 years ago. As for synthetics, manufacturers have learned the can use Group III oils and call them "synthetic", when strictly speaking they are not PAO oils. BUT...group III oils PERFORM exactly as well as PAO's do. So for my money, knowing what I do, I'll take ANY oil on sale, as long as it says SM on it. The synthetic Mobil of Old, was a PAO oil. Now it may have a tiny bit of PAO in it, but it too is mainly group III, in order for CEO to rake in billions of profits. So there is NO REASON to buy Mobil 1, other than to waste ur money. Any Pennz, QS, Valvoline synthetic is exactly just as good as Mobil 1, even SuperTech synthetic is a fine group III that many people use for years, with excellent engine results. Don't waste ur time on Castrol, it too suffers from "CEO needs large bonus syndrome" - its oil, even "edge", is just marketing and promotion. I run synthetic in winter due to better cold properties, and 50:50 synth and conventional in summer, to save a bit of money.
Old 04-15-2009, 08:41 PM
Dakotatech's Avatar
Dakotatech
Dakotatech is offline
Mobile 1 5w30 SYNTHETIC THE ONLY WAY TO GO
Old 08-14-2009, 10:51 PM
sober01s's Avatar
sober01s
sober01s is offline
mobil 1 clean 5000
Old 08-16-2009, 01:01 PM
JDakota92's Avatar
JDakota92
JDakota92 is offline
I'm running Valvoline 10W40 in the Dak and the Escort. I ran Castrol Syntec 20W50 in the Z until I sold it last month. Ericemery, where do you send the oil for analysis? I'm curious on this.
Old 08-17-2009, 12:43 AM
Frenchy's Avatar
Frenchy
Frenchy is offline
I'm switching to Valvoline Platinum 5W20... 5 quarts of that, and one quart Marvel Mystery Oil...
Just to see how things end up that way...
Old 08-19-2009, 12:48 PM
dandragonrage's Avatar
dandragonrage
dandragonrage is offline
I only run German Castrol (Castrol Syntec 0w30 European Formula) in any of my vehicles. Best oil out there. See the discussions about it on bobistheoilguy.com forums.
Quick Reply: Motor Oil
