Old Aug 5, 2015, 09:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Cooling System Guides
Print Wikipost
Thermostat Install DIY
Old May 5, 2011 | 10:47 PM
  #21
Dakkkota's Avatar
Dakkkota
my efan is setted to 160 the t -stat 180 is installed... and i drill that hole with the exact same size (check valve) and the temp almost join the half temp on cold weather...i tested the coolant and i it show the maximum...maybe my coolant is 100% pure...i will flush it out again ...and add a 60/40 new mix.
Old May 5, 2011 | 10:48 PM
  #22
Dakkkota's Avatar
Dakkkota
Originally Posted by Blown287
When I bought my waterpump from GMB they were advertising improved flow over stock. 10% is what they were saying if I remember correctly. I know with the HHR fan, 180 T-stat and GMB my coolant temps stay way low. During the winter I run my stock 200-210 T-stat.
my stocker was 195
Old Jun 5, 2011 | 12:43 AM
  #23
sleds's Avatar
sleds
Great write up with pics for proper direction of the t-stat!
Old Jun 5, 2011 | 12:51 AM
  #24
Eimer123's Avatar
Eimer123
Your welcome! Glad this write up was able to help so many people.
Old Jun 5, 2011 | 12:18 PM
  #25
Dakkkota's Avatar
Dakkkota
helped alot for me this should be a sticky
Old Aug 27, 2011 | 11:43 AM
  #26
Just did this today. Hardest part was they put the clamp on the lower radiator hose right in front of the bolt so I could not get a socket on it...had to use an open end and it took a little bit of time...lol
Old Sep 27, 2012 | 10:15 PM
  #27
604_RS's Avatar
604_RS
Also 180 stat + water pump has moved my temp gauge down from half way to (see picture)
Hello I got a small question. I have the same issue with the gauge. as shown on the image low temp. Whats is the exact issue A. is it thermostat B. Tempeture sensor or C. Tempature sending unit ? Please Help me with this issue ?
Old Nov 4, 2012 | 10:41 AM
  #28
aragon's Avatar
aragon
this is an old thread and probably a stupid question. but do you have to drain all the coolant to install this new thermostat? and is there a 180 thermostat that anyone recommends other than the NAPA one that needs modifying. i would want one i could just throw on and not mess with. thanks
Old Nov 8, 2012 | 11:58 PM
  #29
Blown287's Avatar
Blown287
Yes you have to drain the radiator but it's pretty simple and straight forward.
Old Nov 20, 2012 | 07:30 PM
  #30
DaKoCuN's Avatar
DaKoCuN
Nice write up
Did u have a hot temperature issues? Or what was the reason to remove the temperature sensor?
