3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Rear speakers
Old Feb 12, 2011 | 12:19 PM
jeepgone's Avatar
jeepgone
Default Rear speakers
Went to replace the speakers in my 2011 Club Cab and for the life of me I can't figure out how to remove the panel over the rear speakers. Fronts were easy but the rear panel I pushed, I pulled and can't get them off. It looks easy enough but what am I not doing right?
Old Feb 13, 2011 | 02:49 PM
Altair's Avatar
Altair
Dak attack!
If it's the same as the earlier 3rd gens it's a bit of a pain.
You need to remove the plastic kick plates where the doors open (this can be done carefully without removing the piece at the base of the driver's seat belt).
Then unbolt the top of the rear seat belts.
After this you will be able to pull the top of the rear side panel off.
Then you need to remove the back panel (lower part of the jumper seat back can swing out and I think there's some screws behind there).
(No pic, sorry)
Now remove the rest of the rear side panel and you have access to the speakers.
Old Feb 14, 2011 | 11:37 AM
jeepgone's Avatar
jeepgone
Thank you. I did finally get the panels off, just like you described. It's never easy if I decide to do it myself, but when you're cheap like me and refuse to pay if you can do it yourself, you just gots to do what you gots to do. New Alpine speakers sound great, worth the effort.
Old Feb 14, 2011 | 12:29 PM
gjmoran's Avatar
gjmoran
nice thank you for that, i will be doing the rear speakers in a week or so when i get my tax refund.
Old Feb 16, 2011 | 11:55 PM
Altair's Avatar
Altair
Dak attack!
If you're doing the fronts too make sure to slide the door panel upwards before pulling out after you remove the screws. Wouldn't want to break the plastic "L" hooks back there, the rattling door panel would probably drive you nuts!
