3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Superchips ticks me off....
Old Feb 16, 2011 | 11:37 PM
  #31
Ueland's Avatar
Ueland
Originally Posted by jkeaton
yeah,,,but your gonna explain how i can fix it myself....just like you did yours......call you tomorrow.
Pop the case apart. easiest way was to separate it with fingers or small plastic non marring objects (like a pen) where the USB port is
Do this over a soft table as the board WILL pop out as it separates.
Once Separated, put the board back in the shell, make sure the connector is fully seated (you'll see it when you open it, there's only one connector) then make sure not to pinch the wires under the board when reassembling.
Its pretty easy and straight forward... if you need a hand just gimmie a call...
btw... how'd your bowling go tonight... I'm guessin you sucked *** cause all you could think about was playin with the SC the whole time... lol
Old Feb 16, 2011 | 11:45 PM
  #32
rengnath's Avatar
rengnath
Kent,
How could you not know about the advanced tuning options?
Sincerly,
A very dissappointed fellow DF member.
Old Feb 17, 2011 | 07:10 AM
  #33
Eimer123's Avatar
Eimer123
Here it is Kent!
https://dodgeforum.com/forum/3rd-gen...tm-tuning.html
Old Feb 17, 2011 | 08:05 AM
  #34
Originally Posted by rengnath
Kent,
Sincerly,
Because eimer had not posted that how-to yet.... THANKS EIMER!!!!! (and the fact I never "f"ed around with it enough to find it....lol
OK, just installed a tune with most all tm values set around 15-20%, took it for a drive...do not notice anything different.....no neck snapping shifts...feels pretty much the same as it did before??
Old Feb 17, 2011 | 05:36 PM
  #35
bump....what do you guys "feel" lowering the tm values? I was expecting a harder shift, was that a wrong assumption?
Old Feb 17, 2011 | 05:49 PM
  #36
rengnath's Avatar
rengnath
Youre not driving it hard enough then
My 1-2 is nice. Everything after that is still pretty good, but when I shift in to second at 3,200 RPM, it will get your head moving. Its no shift kit, but it does a nice job. You should notice a huge difference in WOT.
Old Feb 17, 2011 | 07:53 PM
  #37
hmm...maybe i need to play around with it more....just thought it would be something entirely different all around....not just wot...kinda disappointing....but my new tb will make it all better....
Old Feb 17, 2011 | 08:48 PM
  #38
Ueland's Avatar
Ueland
did you change the "part" values too? I know that made the biggest difference with mine...
Old Feb 17, 2011 | 09:09 PM
  #39
yep, set everything at 15-20%. i'll mess around with it some more tomorrow night. it kept resetting itself on me and it took like an hour to finally get a tune loaded...lol
Old Feb 17, 2011 | 10:42 PM
  #40
Eimer123's Avatar
Eimer123
I hear that the Ram guys have set down to 8% I have never gone that far, but maybe I will try it out this weekend.
