3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
New speakers
Old Mar 5, 2011 | 02:52 PM
Default New speakers
Want to get some new speakers. question I have: i have the infinity system. do the speakers need to be 2 ohm or 4 ohm or does that even matter anymore?
Old Mar 5, 2011 | 07:39 PM
Originally Posted by ericemery
they still need to be 4 ohm.
6.5s with an adapter plate.
crutchfield says 6.5 will fit. what size are stock?
Old Mar 5, 2011 | 09:47 PM
guess i need to tear into the door panels to see what i'm dealing with before i buy the speakers.
Old Mar 8, 2011 | 08:25 AM
Ueland's Avatar
Ueland
order from crutchfield and they'll come with the correct bracketry. I got a set from there and thats how mine were...
Just keep in mind the factory speakers are "full range" and actually give more bass then aftermarket speakers, which is why I added a sub.
Leme know when your back in town, I'll bring my truck down and you can hear the difference with and without the sub.
Old Mar 9, 2011 | 08:59 PM
Corks's Avatar
Corks
I just installed my new speakers the other day while it was like 40 degrees outside. I got the wrong size got 5.25 instead of the 6.5 i thought i booked marked. anyways i was able to separate the spacer from the speaker with a screwdriver and then dremeled a couple holes on the side of it and mounted them via zip ties. They hold well and sound pretty good. only trouble is the tweeters they sounds kinda scratchy with the radio
