3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Superchips
Old Nov 18, 2011 | 07:01 PM
Cuban11182's Avatar
Cuban11182
I suggest you get the trans tuning option, you won't regret it. I wasn't happy with it with just the normal tune, but with my custom tune (that I am still tweaking).
What didn't you like? The harsh shifting? If that is the case you can adjust via the TM settings, it's really worth it to be honest. It makes the truck drive like a completely different vehicle.
Old Nov 18, 2011 | 08:40 PM
Sunsetrider's Avatar
Sunsetrider
Originally Posted by wingman_214
Superchips 3865.
Ive tried the 87 and 91 tunes and liked the power gains but couldn't notice the power differance..
Not sure what this means? Seems to be contradictory . . .
I've just now heard about these Superchip thingies and trying to figure out what it's all about. Certainly I am keen to improve my mileage numbers, and I am not pleased with the shift characteristics of my ride. The power of this engine seems somewhat wasted. But it isn't easy to follow this discussion. As someone unfamiliar with the Superchip, I can't decipher the code of the discussion.
I can't distinguish between the "91, 87, 93" references that refer to the octane of the gas being used, and the setting of this Superchip thing being discussed.
Wondering where I can go to read a "primer" on Superchips?
Old Nov 18, 2011 | 11:39 PM
dakotaff's Avatar
dakotaff
91, 87, and 93 refer to tunes that come on the programmer. There are 5 tunes that come on the programmer. The 3 octane tunes, a tow tune, and a mileage saver tune (don't believe the name). The numbers refers to the fuel octane that is needed to run that particular tune. I wouldn't count on the tuner to increase you MPG's, I haven't seen any difference, it always sucks. The Superchips schedule will change your transmission shift points (for the better!) on each of the tunes, simply load up a tune and it's done. It makes a big difference.
This is where it can get confusing.
All of the User Transmission shift scheduling is done after you purchase the transmission tuning option. That you can purchase for an additional $40 from Superchips after you've bought the tuner already. With that there are a few additional setting to change, but this is pretty much the 'basics'.
Old Nov 19, 2011 | 07:31 AM
Sunsetrider
OK, I'm starting to get the drift now. Disappointing to hear the mileage doesn't improve. I'm getting the impression that the benefits might be (1) improving the somewhat sluggish performance of stock, and (2) improving performance with a lower octane fuel. I can see the advantage in improving passing power since I live in a 2-lane world (not a 4-lane environment).
Old Nov 19, 2011 | 04:04 PM
Originally Posted by Cuban11182
I have a question about the lines crossing. When I input my numbers from the tuner listed as STOCK have lines crossing all over the place. Now when I look at the different pages in the Excel Spreadsheet (1up-2dn, 2up-3dn, 4up-5dn, 2pup-3-2pdn, upshifts and downshifts) none of them cross, but when I look at the DATA tab some of them cross over.
So is it alright if I have lines crossing on the Data sheet, but as long as the rest look ok with no intersectoins I will be alright?
Here is the STOCK shift points on the DATA sheet. Every other one there aren't any lines intersecting.
if I remember right, you just need to ensure none of the upshifts cross.
Old Nov 20, 2011 | 04:02 PM
CarlosC.'s Avatar
CarlosC.
A complete newbie here.....and you guys seem very knowledgable....
What does these superchips do, as far as our vehicles are concerned? Is everything done automatically?
Old Nov 20, 2011 | 05:30 PM
wingman_214's Avatar
wingman_214
I could feel the increase over stock on both tunes, but couldnt feel a differance between the 87 and 91tunes.
Old Nov 20, 2011 | 06:01 PM
Superchips is a "tuner", more specifically, it is a handheld programmer for the trucks pcm (powertrain control module). It plugs into the OBDII port and communicates with the trucks computer. It has different levels of tunes depending on your preference. These trucks are programmed to run a certain way from the factory and this factory "program" is designed to maximize mileage over performance. The superchips will "re-tune" the truck and also has canned transmission changes (you can also get the add-on transmission package at an extra cost that lets you have complete control over the shift schedule). Basically, this tuner (or any tuner) is the only way you can get more power out of computer controlled engines and still remain smog legal. it does this by advancing or retarding the timing and also adjusting the shift points, all through a program.
Old Nov 20, 2011 | 09:37 PM
CarlosC.'s Avatar
CarlosC.
Wow, that's cool......Does everybody have to purchase one, or can two dodge rams use the same programmer?
Old Nov 20, 2011 | 09:55 PM
thunder98110's Avatar
thunder98110
they are vin locked, so no. unless you both have the same PCM p/n but thats rare.
