3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Resonator Delete
Old May 8, 2012 | 10:27 AM
blakdak07's Avatar
blakdak07
The thrush has an offset outlet. I turned it vertically to help drop the 90* under the frame. With your choice of tip, could look spectacular.
Old May 17, 2012 | 12:04 PM
blakdak07's Avatar
blakdak07
That didn't work. Try again.
http://youtu.be/-QTyRh-VhLA
Old Aug 16, 2016 | 03:56 PM
team_dodge's Avatar
team_dodge
So you won't loose any hp or torque? ?
Old Aug 23, 2016 | 10:25 AM
i.who.made.you's Avatar
i.who.made.you
No. In theory reduced back pressure would help the engine run more efficiently (more power to the wheels) but on occasion exhaust exiting under the vehicle will exit into a high pressure pocket increasing back pressure but IDK if this ever really happens... TL;DR People do this all the time and it doesn't change horsepower and it sounds the same. Get a dump valve.
