3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Resonator Delete
Old May 3, 2012 | 01:05 PM
dsimm87's Avatar
dsimm87
Question Resonator Delete
Ive got a 2007 4.7L and I want a little more rumble in the exhaust. I don't really have any money to spend so I was thinking of getting rid of that ugly rear resonator (just cutting it off and leaving it dumped). I'm not really familiar with exhausts so what should I expect if I do this? Thanks!
Old May 3, 2012 | 02:31 PM
FrenicX's Avatar
FrenicX
That's what i did, but I removed both resonators and changed the muffler. Having it dumped worked out just fine, going over the rear axle helped with the drone a lot.
IMO, removing just the back res won't do much for you. When I did mine, I removed the muffler and back resonator, put a thrush welded on and left it dumped there... it was too loud so I put the severed tailpipe back on and it was perfect, aggressive but definitely not loud. I wanted more noise to I took the front resonator out too, leaving the thrush muffler and cut tailpipe.
If you want a cheap solution, the thrush mufflers are about 30-50 from parts places, an 18" 2.5 extension is $10 or less (not the res-delete pipe, you need a female-male one, delete pipes are female-female) three 2.5 clamps at $2.50 each. If you ordered the muffler from Amazon, it's around $29. It has a nice rumble at idle, but doesn't scream like mad under heavy acceleration.
muffler $30
clamps $8
ext $10
Old May 3, 2012 | 04:33 PM
marcsnyder05's Avatar
marcsnyder05
I did pretty much the same thing except I had only one resonator and I used a cherry bomb glass pack pretty much the same as what FrenicX used. at one point I had it dump before the rear axle but it had too much drone so I had it run back over the rear axle and it's a lot better. I spent about $200 cause I had a shop run it back over the axle.
Old May 3, 2012 | 05:16 PM
just removing the rear resonator wont do a thing.
Old May 3, 2012 | 08:21 PM
dsimm87's Avatar
dsimm87
the 2007s only have 1 resonator right? regardless, looks like I'll just wait and get a new system. theres a nice fam owned business here and the price isn't too bad.
Old May 3, 2012 | 08:25 PM
rebel4055's Avatar
rebel4055
Got rid of both my resonators. With one off there was any sound at all. Took the other one off and opened the system up. I had it turned down by the rear axle too. Lots of weight shaved off when I did that too. Lets the truck breath better too I guess lol.
Old May 4, 2012 | 11:13 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
You are right, just behind the rear tire... we were lucky and didnt have 2 resos, although we do have that damn huge muffler like everyone else.
Old May 6, 2012 | 02:49 PM
blakdak07's Avatar
blakdak07
I got the thrush welded muffler and a 90 degree piece. That put it out just in front of the rear wheel. I'm currently looking for a camaro ss rectangular tip to finish it up.
Old May 7, 2012 | 11:51 AM
How did you get over (or under) the frame?
Old May 7, 2012 | 03:28 PM
FrenicX's Avatar
FrenicX
I was looking back there the other day, there's enough room in front of the rear tire, where the frame rail turns upward, to tuck a decent amount of the pipe without worrying about the frame.
