3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
lowering question/issues
Old Apr 7, 2013 | 10:19 PM
remme's Avatar
remme
Default lowering question/issues
Have 2005 Dakota 4x4. Lowered the rear by relocating the spring perch and bundle to under the axle and replacing the stock perches w 2" lowering perches. My question is if I add "add a leaf" leaves to the spring bundle would that lift the truck higher or force the suspension lower because its underneath the axle instead of over it? I can't imagine it in my head....ha. I want them to have the extra pay load capacity because the truck is still used to do truck things in....thanks
Old Apr 8, 2013 | 10:59 AM
Good question.....to which I do not know the answer...lol
Old Apr 8, 2013 | 11:54 AM
Alfons's Avatar
Alfons
Anything that would increase the arch or the spring would lift the truck, regardless of whether the spring center is mounted above or below the axle. Many bolt-on add-a-leaf products don't actually increase the arch but increase the stiffness to allow move load. To change the arch, you need to get a spring shop to take the pack apart and re-arch each leaf to give you the lift (or sag) that you want. The jeep springs I've had re-arched cost me around $150 each.
Old Apr 8, 2013 | 12:19 PM
projektdirtfab's Avatar
projektdirtfab
Being that your now sprung under. Adding a leaf wouldnt affect ride height. You would just lose a few threadson your u bolts so make sure they have enough threads for the thickness of the new leaf.
