3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
What size 17s to buy?
Old Sep 4, 2013 | 06:32 PM
madredr1's Avatar
madredr1
Default What size 17s to buy?
I want to get some black wheels and there's all kinds of offset and backspacing listed on the wheels. My truck is 2wd with 16s right now, what should I be looking at for wheel offset and backspacing? I don't want it to look any different than stock, and I don't want to have to do any trimming...
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
These are the ones I was interested in...
Old Sep 4, 2013 | 08:14 PM
dakotaff's Avatar
dakotaff
Our stock wheels are 16" x 8", with an offset of 25.44mm. So keep it the same offset to keep the stock stance.
Old Sep 4, 2013 | 09:54 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Keep in mind that offset will change with wheel width. Thus, if one increased to a 16x9" wheel with the same 25mm offset, the inside lip of the wheel would be a half inch closer to the frame. One would want to do a +12mm offset to achieve the same backspacing.
Old Sep 5, 2013 | 02:55 AM
djibara's Avatar
djibara
What about the stock 17x8 chrome 5 spoke option then plasti cote
Old Sep 5, 2013 | 06:59 AM
dakotaff's Avatar
dakotaff
True about the increased backspacing with the wider wheel, but even with a 9" wheel (with 25 offset), there aren't any clearance issues with our Dakotas. At least two members, (or 3 IIRC), are running 20" x 9" & 25 offset with no issues and a stock stance. The 12 offset will push the tire out a bit, not a lot though.
Old Sep 5, 2013 | 05:36 PM
madredr1's Avatar
madredr1
So, I get those wheels and slap some 265/65-17's on there, there shouldn't be any rubbing?
Also, nice looking truck you have there!
Old Sep 5, 2013 | 09:12 PM
djibara's Avatar
djibara
If it helps I have 275/60R 17s on my 05 Quad cab the sticker on inside of door jam says factory size
Old Sep 5, 2013 | 10:13 PM
donkeypunch
King Jackass
I agree. I wasn't doubting the fitment on our trucks, just saying that the offset does not equal the same backspacing on a different wheel with a different width. My factory steel 16x7s have a +25mm offset, resulting in a 5" backspacing. My 285s rub the frame at full lock. But then again, I'm running 285s on factory wheels....
Old Sep 6, 2013 | 08:04 AM
dakotaff's Avatar
dakotaff
Thanks. And yeah, those wheels and 265/65/17 tires should bolt up with no issues at all.
