IPCW tail lights question????
Does anyone have a video of the IPCW tail lights? Looking on getting some, just wondering how it works? It looks as if the running park light and the brake light are separate.thanks in advance.
Unless it was different on some, mine were all LED except for the white reverse bulb, so if you wanted full LED and/or better light when backing up, you'll still have to get a good set of LED bulbs that are compatible with the 3157's (<--- I think that numbers right) and just plug away.
Well what I'm asking is, is this with the running lights on? Than when you apply the brake the one in the top middle lights up or is it just a reflector? When applying the brakes do the intensity of the LED's get brighter?
Asking these questions because I want to purchase this setup, as well as install Flasher modules, so when I apply the brakes it flashes really quick than solid. Just want to know how it works so I will know how much time I'm going to spend on installing them.
Yea the top middle is just a reflector. That is with the running lights on. When breaking or using the turn signal the brightness of the LED's do intensify.
Thankyou!
