3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Just grenaded my t-case
Old Nov 10, 2016 | 02:01 PM
Spucknit's Avatar
Spucknit
Default Just grenaded my t-case
I've spent the last few days worrying about half shafts that had started clicking and wouldn't you know it. The t-case exploded while going 80 on the freeway. Murphy's law I guess
I have a 2005 Dakota Laramie with the AWD transfer case. I was wondering if anyone knew if I could replace it with a standard 4WD case?
Old Nov 17, 2016 | 02:27 PM
dakotaff's Avatar
dakotaff
That question has been brought up numerous times, and there never seems to be an actual swap confirmed. Some say you can simply swap from Full time 4WD case to a Part time 4WD case, and some say you also need to have the computer flashed by the dealer.
Hopefully someone can confirm if it is a simply hardware swap or not.
Old Nov 17, 2016 | 09:26 PM
primem's Avatar
primem
http://www.dodgedurango.net/forums/d...-complete.html
the awd rpo is new venture gear nv244
Old Nov 17, 2016 | 09:33 PM
primem's Avatar
primem
not sure how the 244 awd works...some models run in 2wd until wheel slip is detected and them power a clutch to transfer power to the front axles. if this is the case, i don't think i'd make the change. If it was a true awd with a ptu i would change it.
