3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Carpet for Extended Cab 2008
Old Aug 5, 2017 | 07:44 PM
CliveW's Avatar
CliveW
Default Carpet for Extended Cab 2008
Is the crew cab carpet the same dimensions for the front of the cab as the extended cab.
I have a very smelly carpet in my 2008 extended cab Laramie. The only under $150 carpet I can find it a crew cab. I would like to buy it and cut it to fit the extended cab but want to know if it's just the length that would need trimming..
Thank you
Old Dec 4, 2017 | 01:24 PM
JD Smith's Avatar
JD Smith
Did you ever find a solution? Can you cut down a quad cab carpet?
Old Dec 29, 2017 | 01:06 PM
Cwvega76's Avatar
Cwvega76
UPDATE FYI - All research reveals that no one makes a replacement for a crew/extended cab Dakota. I took a chance and ordered the replacement carpet for a quad cab from CARID. It came in box labeled ACC Carpets.. Yesterday I installed it. I had to cut off about a foot from the rear. It took some doing, and there are some wrinkles underneath those rear jump seats, but I am happy with the result.
