180 Degree thermostat
Old Apr 19, 2007 | 05:34 PM
  #22
Casper50's Avatar
Casper50
Default RE: 180 Degree thermostat
It will slightlyrichen the mixture but the stock t-stat is 195 so there really isn't much change. Our trucks are able togo into closed loop at 165 as long as everything else reads right. As long as you hit closed loop you should be ok, anything before that and the truck will be puking fuel because it is trying to warm up.
