Need Mod help
Old Apr 11, 2007 | 06:35 PM
Casper50's Avatar
Casper50
Default RE: Need Mod help
Yep, it has an 5 speed auto with the V8 but 2nd gear has 2 gear ratios depending on which way it is shifting. If you hit the throttle and it down shifts to 2nd you will have a 2.62 gear ratio and if you are starting off the line and up shift you will have a 2.50 gear ratio.
I don't think switching to a factory 6 discwill mess with the bluetooth because I have both from the factory. I'm sure it's just a plug-in to the back of the unit. I don't think you could go with an aftermarket one unless it also had the ability to support the bluetooth
Old Apr 11, 2007 | 06:55 PM
mb18's Avatar
mb18
Okay, I've been checking into the Bluetooth thing for the last 45 minutes or so (it's been sloooooow today). Casper's right, it should work fine with the factory 6-disc...it' just be plug and play. No flashing required either.
Replacing with an aftermarket receiver won't allow the UConnect to continue working...every receiver that I looked at online clearly said that, and, from looking at the wiring diagrams, I can see why...the special inputs for the UConnect just won't be there. You could get a receiver with Bluetooth in it, but then you'd still lose the functionality of the mirror. It's a shame really.
Old Apr 11, 2007 | 07:39 PM
RMUDBUGS's Avatar
RMUDBUGS
I love my AEM Brute Force intake. It sounds great and the filter does not have to be oiled.
Old Apr 11, 2007 | 07:41 PM
Cuban11182's Avatar
Cuban11182
Totally off subject I was just saying goodbye to my old forum wishing them best and so on and I totally got slammed
http://coloradofans.com/viewtopic.php?p=632568
Old Apr 11, 2007 | 07:50 PM
mb18's Avatar
mb18
LOL...I was/still am a member over there from my GMC Canyon days. I still check in every once in awhile to see how many of them are getting new/rebuilt heads (like my old one needed). They can get a little crazy about those trucks, too...especially if you've ever visited the 'Competitors' board.
Sorry, didn't mean to continue the off topic, but had to chime in.
Old Apr 11, 2007 | 08:28 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
LoL. What a good choice both of you made ditching the colorado/canyon. That things horrible. Rubbermaid on the inside, cut corner body, made of aluminum foil. straight 5? What are we on the moon?? Like the dice man says: "Get 'em the F*CK outa here!!"
Old Apr 11, 2007 | 09:17 PM
Altair's Avatar
Altair
Dak attack!
Lol, that's a load of crap that they're all slamming you. You made the right choice by far, Chevy should have kept the S10, that was a lot better than the colorados/canyons are.
