General Grabber AT2 on truck
Subscribe
Apr 19, 2007 | 07:14 PM
RE: General Grabber AT2 on truck
Quote:
ORIGINAL: trucky
dag GONE it bjk, now im second guessing my BFG a/t KO's ... i had it all planned out now i dont know what i want...thanx a lot.
does anyone have pics of the bfg's? i cant tell if the generals are more or less rugged...
Well, here's a close up of them on a Raider.
[IMG]local://upfiles/56037/174D1EC52430493AAA0F7B4174CF79C1.jpg[/IMG]
Reply 0
Apr 19, 2007 | 07:39 PM
Those look real nice, definitely getting some as soon as I wear down the stock tires. I'll probably grab the 265/75's, I don't plan on going over 90 much anyway.
Reply 0
Apr 19, 2007 | 08:38 PM
Quote:
So what the the size of those in inches
30.9 inches...So I would say it's all but a 31x10.5x16
Reply 0
Apr 19, 2007 | 09:13 PM
AGH! now i want to change my mind and get generals... i would like to know about the clearance because i want 265/75
Reply 0
Apr 19, 2007 | 10:26 PM
It's just that the 75's (in the General Grabber AT2) are LT's which on their spec sheet shows max air pressure at 88 psi...Not the regular 44psi...I just didn't think I wanted a tire that used that much frikin pressure....But I did see a another tire of the 75 size and it wasn't really that much taller...They are slightly skinnier though.
Reply 0
Apr 19, 2007 | 11:49 PM
oh...so maybe i want 70...i want wide and tall... and why would pressure be doubled?
Reply 0
Apr 20, 2007 | 12:09 AM
LT - light truck
Mainly for having more stuff in the rear, and different driving styles.
I know at 88psi the ride will be jarring.
Reply 0
Apr 20, 2007 | 12:11 AM
The tire shop guy said that they're used on heavy duty commercial-type trucks that carry alot of weight all the time. Now so much for "play" trucks like ours..So I guess the extra air pressure is to allow the heavier capacity? Anyone really know?
Reply 0
Apr 20, 2007 | 01:08 AM
I know that with my old car at least I had called the tire company (kumho) to ask about inflation pressure, and also the tire place and they both said always go with the factory recommended tire pressure on the door. Max inflation pressure doesn't mean the tire should be run at that psi. Granted that wasn't a truck but I would assume it still holds true. If in doubt why not give general tire a call?
Reply 0
Apr 20, 2007 | 11:27 AM
Yeah, the BFG's that came on my truck are the LT series and I run them at 35psi all the way around. The only reason that they canhold more pressure is because the LT tire is built with a higher ply rating than a P tire. Basically the LT is built a little stronger so that you can carry a heavier load. The load ratings are C, D, and E on the LT tires. The ply count for the tires are P=4 ply, C=6ply, D=8ply, and E=10ply.
Pointless rambling done!
Reply 0
