jet chip
Old Apr 29, 2007 | 05:25 AM
trucky's Avatar
trucky
Default jet chip
hey my truck is finally coming tuesday after5 months of anticipation... and i just got done ordering a stage 2 jet chip. and im gonna get it installed with my thermostat thats in my glove compartment. i will let you know how it goes.
but anyways i went ahead and got the chip because autoanything.com is having a 20$ off when you redeem the code at checkout for large orders. so i got a stage 2 for $210 shipping taxes and everything....best i have EVER seen.
Old Apr 29, 2007 | 01:37 PM
luvmydak's Avatar
luvmydak
Default RE: jet chip
That's a good deal. I got mine from AA also but at that time there was no discount deal so I paid full $230.95 but free S&H. Important: follow install instructions exactly....it's the second connector down on the PCM(white color coded). Disconnect neg batt. terminal before starting and reset PCM BEFORE reconnecting batt.: reset by turning ignition to START and holding for 15-20 sec. Some members say startingtruck 3 times one after the other and leaving it run after the third start for 5-10 minutes works for them. Seems like a waste of gas to me. I used my method when I installed my CAI, installed my Jet chip/180 t'stat,and modified throttle body install. Always worked for me, never had check engine light come on ever.
Old Apr 29, 2007 | 01:58 PM
Dusty's Avatar
Dusty
Please get before/after 1/4 times, or dynos even.[8D]
Old Apr 29, 2007 | 04:36 PM
trucky's Avatar
trucky
im doin self dyno. gonna put my camera on the dash display and record myself 0-60, 1/4, and WOT times from certain speeds before and after the chip. seems like a more accurate thing to do if you ask me, i will be able to see for myself the RPM changes and i'll have a timer to check the other stuff... (cheap too)
Old Apr 30, 2007 | 02:53 AM
trucky's Avatar
trucky
should i install the jet chip myself or get it done? how much would a shop charge to put it in with a thermostat cuz i have one in my glove compartment (180) that needs put in too... i know i cant do that myself i have no tools here.
