Exhaust Install
Exhaust Install
I bought an exhaust kit from ebay (magnumexhaust) but I'm having a bit of trouble installing. Finally got the old system apart but before I throw in the towel and take it to a shop, does anyone have any good pics of theirsingle in, dual out flowmasterinstall? Figure, I may be able to get a better idea if I can see a picture or 2. Kit only removes the muffler and the rear resonator so I'm not real sure how to position the extension pipe (if needed)nor the muffler. Plus using the hangars might be an issue.
Thanks.
Thanks.
RE: Exhaust Install
i wish you talked to us before getting the kit. some kits are for early model daks and then for later models. they made some chenges. most of us just bought mufflers and had a shop bend and hang pipe. mine was 250.00 out the door. 3 inch catback. you may need to fab up some sort of bracket on the oppisite side of exhaust to hang the system. as far as the extension pipe it is for quad cabs. your best bet would be to assemble system in driveway to see how it would look. then take it apart and install on truck
Guest
Posts: n/a
Trending Topics
