Combining both leveling kits...
Old May 1, 2007 | 03:08 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Default Combining both leveling kits...
Is this possible? Im not sure if there would be all sorts of binding issues oooor if it would squeeze by. I know that the struts would only be taking 2" of punishment because the trailmaster kit (the one I have now) Is the only one that effects them. The Truxxx kit drops the whole assembly.
Probablly cant be done but anyone have any idea? Or, know a way to get a few more inches out of the front end?
Old May 1, 2007 | 03:20 PM
Night_Runner's Avatar
Night_Runner
Default RE: Combining both leveling kits...
you can have both...i just googled it and found a ranger with a 4" suspension lift and a 3" body lift...so its possible
Old May 1, 2007 | 04:18 PM
turbot_bird's Avatar
turbot_bird
I think he means two leveling kits not a suspention and body. Idk if you could do two different suspention kits together
Old May 1, 2007 | 04:22 PM
Night_Runner
ah ha
Old May 1, 2007 | 09:22 PM
pro4x4's Avatar
pro4x4
I think a 2 inch lift is all that is possible with these trucks. Any higher and you need a full suspension lift kit. One with a subframe to lower the front axles and keep the suspension geometry at factory angles or you risk damage and binding problems.
Old May 2, 2007 | 01:47 AM
nowick's Avatar
nowick
yeah any more would be pushin it or just carry extra u joints
Old May 2, 2007 | 03:26 AM
Altair's Avatar
Altair
Dak attack!
I'm not going to say it wouldn't work because I don't know, but I wouldn't risk it on my truck. I have a feeling you'll be replacing axles and other various parts in a few months if you combine the kits.
Old May 2, 2007 | 05:12 AM
jimboscomp's Avatar
jimboscomp
I had this same question, but never got off my lazy butt to go and ask it. This answers it though. Think i'll stick to the kit that stiffens the springs a little, give it a bit more hold up under stress.
Old May 2, 2007 | 07:41 PM
herkguy's Avatar
herkguy
I think the Truxx is for two wheel drive only use, in this case you would be fine I think. The Truxx aren't recommended for 4wd all though they will bolt up.
Old May 3, 2007 | 01:52 AM
rookie's Avatar
rookie
I've heard that the truxx kit will bind a 4x all by itself. Instead, I would add a spacer on top of the TM kit and try and cheat it up to 3." look at your CVs, if they are flexed down a lot on level ground, then they are going to wear out faster. The TM kit flexes them down, but it's not that much. I think an additional 3/8" spacer would give you a littlextra, safe lift. just an educated guess. My buddy has a silverado w/ cranked torsion bars(about 3" lift, but factory suspension).His front CVs are flexed pretty good, and he has had no problems for15,000 mi. BTW, he babies his truck.
