idle trouble
Old May 7, 2007 | 01:15 PM
trucky's Avatar
trucky
Default idle trouble
does any one get a really bad idle when they are cranking out the power steering at slow speeds? when i make a sharp turn in a parking lot my truck almost turns off the jumps back to life...is it supposed to do that?
Old May 7, 2007 | 09:05 PM
superdak05's Avatar
superdak05
Default RE: idle trouble
yes, thats the way the sensors work. when i was in dunkin donuts drive through it happens alot. nothing to worry about
Old May 7, 2007 | 10:13 PM
trucky's Avatar
trucky
yah my truck shut down in a drive through a few times...ok good to know
Old May 7, 2007 | 10:40 PM
turbot_bird's Avatar
turbot_bird
is it when you hit the locks or just normal turning?
Old May 7, 2007 | 11:49 PM
trucky's Avatar
trucky
it's only when im a cupple inches or less from each turn limit
Old May 7, 2007 | 11:52 PM
turbot_bird
oh.....
Old May 8, 2007 | 01:37 AM
mb18's Avatar
mb18
ORIGINAL: trucky
I can understand rough idle, etc...but when it shuts down when you're pulling a hard turn at low speed doesn't sound right. I'd get that checked out.
Old May 8, 2007 | 10:50 AM
curtiplas's Avatar
curtiplas
Well I know you can definately do that with a manny...but Idk if it should be shuttin down with an auto tranny...the problem is that when you crank the power steering ur putting a larger load on the engine so it has to handle it but if its idling too low it will start to stall... whether this is a design prob with the dakota...or a sensor prob with ur particular dakota...idk...but thats all just my 2 cents anyway.
