center console questions
Old May 15, 2007 | 02:30 PM
patman0323's Avatar
patman0323
Default center console questions
i have an 06 with the split bench front seats. what im looking to do is take out that center seat with the armrest on it and replace it witha new console. what im looking for is either one of the ones from the older model dakota's or get the center console that comes with the dakota's with bucket seats.
what my real question is has anybody tried this? will it work or will i have to pull the front seats and get the buckets to get the console?
any information would be appriciated
Old May 15, 2007 | 02:31 PM
Frenchy's Avatar
Frenchy
Default RE: center console questions
should work...
I cant see why it wouldnt...
im sure it bolts up to the same spots in the front, and prolly something like where the seat bolts up in the rear...
Try it?
Old May 15, 2007 | 04:27 PM
Altair's Avatar
Altair
Dak attack!
If you have split bench I think the center seat/console is part of the drivers seat (or maybe it's the passengers) they may not come apart.
Old May 15, 2007 | 04:39 PM
mb18's Avatar
mb18
I have the split bench...it's a 40/20/40 split....the center section is indepedent of the other two (and doesn't move). The console is attached to the floor.
Old May 16, 2007 | 02:27 AM
Altair's Avatar
Altair
Dak attack!
Oh yeah, I shoulda known that lol, I have the split bench. I'm too young for my memory to be goin already
Old May 16, 2007 | 02:53 AM
rookie's Avatar
rookie
patman, I want that seat! I'll give you a little jingle for your console project. I'm in wv. Where you at? If the shippings reasonable I'll make it worth your while.
Old May 16, 2007 | 09:11 AM
patman0323's Avatar
patman0323
im located in ny, 12309 area code and yeah that sounds good.
Old May 16, 2007 | 04:58 PM
rookie's Avatar
rookie
I will look into it. probably UPS. I know it's big, ya think it's under 50lbs?
Old May 16, 2007 | 05:28 PM
rookie's Avatar
rookie
Here's the deal: If it can fit in a 25x25x25 box and is around 50lbs, it'll cost around $46 to ship. The size of the box is crucial. If you add lenth+2xheight+2xwidth(length + circumference)the total must be under 130 inches. The seat is only around 10-12 inches wide, so, provided that you can find the right box it should work. how much do you want for the seat?
