Speed grille inserts fixed
Old May 25, 2007 | 11:53 PM
pro4x4's Avatar
pro4x4
Default Speed grille inserts fixed
I bought a whole new speed grille kit and fixed the passenger side insert that I cut so I could open the hood. Now I use a screw driver and stick it in the hole closest to the hood release and it opens. I am working on a more permanent way to open it though. Maybe I can make the hood latch a little longer or something like that. Can't upload pics here too big so you will have to visit my cardomain page
Old May 26, 2007 | 12:43 AM
trucky's Avatar
trucky
Default RE: Speed grille inserts fixed
what's so hard?! you tie a cable from the hole in the latch down the black grille frame and tie it loose so you can reach under your grille and pull it to relase it! thats it!
Old May 26, 2007 | 03:29 AM
Frenchy's Avatar
Frenchy
Show him a picture man...
I know I didn't understand what was being said til I saw a picture, then I felt retarded for not getting how to do it in the first place...
Old May 26, 2007 | 03:38 AM
trucky's Avatar
trucky
there are pics in the post i started called 'girlles'
Old May 26, 2007 | 03:49 AM
Altair's Avatar
Altair
Dak attack!
I was bored so I went and dug up the pics from that thread:
ORIGINAL: ETXDak
Yea I posted about it before and got the you can go to hardware store and get gutter mesh and do it yourselfreplies. The inserts this guy sells are pan shaped and its heavy duty expanded mesh aluminum and held on by wire ties. I had to drill like 6 holes for each panel but you have to get on your hands and knees to see how they're attached. I'm sure if your not comfortable with the ties you could use screws or rivets.I installed them last fall,so far so good.Here'ssome pics of the set up I made to pop the latch.
[IMG]local://upfiles/39512/74857431DA0D4D4D93465D7E61E435F2.jpg[/IMG]
[IMG]local://upfiles/39512/7EF51503F197468C8AD436B5E5304E4E.jpg[/IMG]
Here's the thread: https://dodgeforum.com/m_791797/tm.htm
Old May 26, 2007 | 03:51 AM
trucky's Avatar
trucky
haha thanx man LOOK PRO4X4
Old May 26, 2007 | 05:27 PM
pro4x4's Avatar
pro4x4
Alright so I'm a little slow ok. I even printed the pictures. Well at least this setup looks like it will work better than the one that comes with the insert kit.
Old May 27, 2007 | 01:31 AM
Frenchy's Avatar
Frenchy
It's what I did...
Works perfectly fine for me.
