Have you seen me?
Old Jun 4, 2007 | 02:30 PM
rotormunky's Avatar
rotormunky
Default Have you seen me?
Howdy all,
Have a couple quick questions... wondering if anyone here recognises the following items:
First is this the 'auxilliary transmission cooler' listed in my buildsheet?
If so I worry that it's pretty wimpy. Would it be worth replacing it w/ a proper finned radiator type?
And is this the outside air temp sensor I have heard ppl talk about? Been wanting to either get one of the smart consoles in which case I assume the wires from this bugger can be found int eh drivers side a-pillar. Otherwise its one of those ebay mirrors which may or may not work with this sensor which means I have to run another sensor (prob along same path I imagine).
THanks for any input you guys can provide.
Old Jun 4, 2007 | 04:02 PM
Altair's Avatar
Altair
Dak attack!
Default RE: Have you seen me?
That could be the aux cooler but I find that hard to believe. My last truck had what looked like a mini radiator for the transmission cooler from the factory, that doesn't look like it would do much.
Old Jun 4, 2007 | 05:32 PM
DakotaStone's Avatar
DakotaStone
Follow the lines and see if that's where they go. I thought the same thing, but never looked into it.
Old Jun 4, 2007 | 07:43 PM
curtiplas's Avatar
curtiplas
That looks like the air sensor but I thought the air was located by the Throttle body... Correct me if I'm wrong guys.
Old Jun 4, 2007 | 08:55 PM
superdak05's Avatar
superdak05
that is the sensor for the onboard computer. if you have the overhead console. as for the cooler that is not. you should have a little mini radiator for that. some how that looks like lines for the a/c unit.
Old Jun 4, 2007 | 10:47 PM
turbot_bird's Avatar
turbot_bird
that looks like a power steering cooler like on my bird. and yes that is the sensor for the overhead console
Old Jun 4, 2007 | 10:50 PM
pro4x4's Avatar
pro4x4
I know that in the second pic that is the air temp sensor. The first pic The tube that runs around the front of the a/c radiator could be for the power steering. If you have the trx or txr whatever its called offroad suspension or even I think the towing package you have an auxilary cooler for the power steering.
Old Jun 5, 2007 | 05:08 PM
Cuban11182's Avatar
Cuban11182
Yup thats the Power steering cooler. The Trans cooler is at the bottom of the radiator built in. Im gonna put on an after market on eventually
